Clutch or motor stumble
Old Aug 21, 2006 | 01:39 AM
06cobaltls's Avatar
i have just bought my new cobalt on thursday, and i have started to notice that when shifting thru the gears that is starts to seem like the motor kinda stumbles or as if the clutch isnt staying engaged the entire time, feels like you go back in forth in your seat at times just not alot, i only have put 225 miles on the car, and it had 300 when i bought it, so i was just wondering if anyone else has ever noticed this, and i am not a bad driver, i used the stock clutch on my eclipse to 75k when i traded it in
Old Aug 21, 2006 | 01:44 AM
sealy's Avatar
are you shifting at really low rpm's?
if so trying shifting higher...i usually go at least to 3k maybe more like 3.5k until i shift. unless im on flat ground.
Old Aug 21, 2006 | 01:54 AM
06cobaltls's Avatar
sometimes, but it happens at higher shifts as well, i will try shiftin higher, but i thought it was ok to shift low, the eclipse i could shift it to where the rpms were under 1500 and have no problems guess i gotta get used to the new car
Old Aug 21, 2006 | 12:36 PM
NLCobaltSS's Avatar
I just bought mine and i find the exact same thing that you explained. I just hope it is where the car is new still.
Old Aug 21, 2006 | 11:15 PM
06cobaltls's Avatar
i am going to take mine to the dealer tomorrow they have to fix a scratch that was on it when i bought it, i will try and get some answers then,
Old Aug 21, 2006 | 11:16 PM
05BlackCobaltSS's Avatar
Yea, just let the RPM's go up another 250-500. That should smooth the ride out for you.
Old Aug 21, 2006 | 11:20 PM
joeworkstoohard's Avatar
yeah, when i loaf along, i granny shift, but the car doesn't seem to like to run at low RPM with little to no throttle application.
Old Aug 21, 2006 | 11:21 PM
TheYellowSS's Avatar
good choice, i had the same problem when i first got my car, but when i told the dealer, they said to break it in and there was nothing wrong. now 5000 miles later i had to buy a new clutch because of the same reason. take it back, have them make sure everything is smooth. dont make my mistake.
Old Aug 22, 2006 | 12:21 AM
vanillathrilla's Avatar
I notice it in second gear at lower rpms...kind of stutter steps
Old Aug 22, 2006 | 12:25 AM
06cobaltls's Avatar
feels like the air conditioner is kicking on and off to me
Old Aug 22, 2006 | 08:57 PM
FraGmE's Avatar
yea just got mine and have it with 600km's now after 1 week and I notice the same stutter step in 1st or 2nd when shifting in low rpms... i'll try that higher shift too see if it goes away
Old Aug 22, 2006 | 11:19 PM
brianm01's Avatar
I got 30k on mine and it still does it, Its from lagging the motor.
Old Aug 23, 2006 | 01:54 AM
06cobaltls's Avatar
i went to the dealer but they were to busy to look at it, have to try again today, i dont think that the motor should do that though, should be able to shift at any rpm with no problem other then under 1500 or so i could understand that, but to shift at 3000 and still have the problem in all gears including sometimes in 5th i feel it, i dont think that is right, and if they cant fix i think its bullshit
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
