Clutch pedal limp on wot
I've just started having a problem in the past few days where my clutch pedal goes limp during wot shifts. It'll be limp halfway in and get stiff all of a sudden close to the firewall. It never does it on light shifting however.
I'm assuming either I need to bleed the brakes and clutch or replace the tob. Has anyone else had this problem? And if it is the fluid, what would you recommend changing to? The last time I did my brakes, I used dot4 oreilys brand, because I didn't know what else to use. That was only about 10k miles ago
I got the same problem. probably the tob. im changing clutch soon so ill see whats wrong in there. mine started after tuning on zfr, after a bunch of hard full throttle pulls. had a burning smell after the pulls with windows down. ill let u know what is found
Sl0wbaltSS
Nov 21, 2018 11:11 PM
