Clutch pedal sticky/slow after a hard pull
Old Sep 16, 2014 | 09:51 PM
jvirginillo's Avatar
Thought I would add to this thread. I had this problem after installing a LUK clutch and as described would be most noticeable when doing a high RPM 1 to 2nd pull. Often could not shift to 2nd.
I had my fluid changed and bled a couple of times.
I also noticed it would happen on my commute home on a hot day. I would exit the freeway after about 40 minutes driving at 60 MPH and go to gear down and no clutch.
The way I would 'fix' this once I knew it was going to happen or started feeling a 'low' pedal engagement was to push the pedal down and slip my foot off allowing the pedal to 'snap' back.
After doing this I would get back to normal operation.
When I put in the GMPP I also installed a stainless line.
I had attributed it to the stock clutch line being soft and perhaps flexing? Could be that going to the GMPP resolved the issue.
Only thing I can say is it was one of the most annoying things until I got it fixed.
Old Sep 17, 2014 | 07:02 AM
tomj77's Avatar
Where did u get the stainless line
Old Sep 17, 2014 | 08:30 AM
Supercharged06SS's Avatar
I had this problem. Brake fluid was black. Flushed it out now no problems at all. So definitely check your fluid first
Old Sep 17, 2014 | 09:10 AM
tomj77's Avatar
Ya I'm gonna try flushing clutch, I did the brake fluid a year ago, but I also changed a caliper a month ago so I could still have air in the system. I shall try both these things and see what it does.
Old Sep 17, 2014 | 10:46 AM
THMotorsports. They are a supporting vendor.
Old Sep 17, 2014 | 11:25 AM
tomj77's Avatar
Can't find it on their site. I'll have to pm. What u pay for it?
Old Sep 17, 2014 | 03:37 PM
65 shipped. Just google stainless clutch line mth motorsports cobalt
Old Sep 17, 2014 | 07:30 PM
tomj77's Avatar
I got f35 tranny, that one is for f23
Old Sep 18, 2014 | 01:37 AM
According to their post it is for F35 they were trying to make it for f23 but no one sent their stock line in for R&D
Old Sep 18, 2014 | 01:38 AM
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/thmotorsports-stainless-steel-clutch-line-kit-no-one-else-one-finally-out-283322/
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
