clutch pedel pushrod broken help me
i have an 07 ss/sc i cant get to it right now to even look at it but the pushrod from my clutch pedel to the master cylinder broke i need to know the best way to fix it without being able to see it can i replace the pushrod itself or do i need a complete unit if u have any info that can help me out plz send me a msg i appreciate it
It'll probably be an entire unit. In my experience the pushrod comes pre-inserted in the master cylinder and is not available seperate. Moreover, I'm not sure that you could replace it individually anyway due to the nature of the seals on the backside of the master cylinder.
Man how did you break that.its desingned to take alot more force than you should be able to put on it.
If you are that stong ,you sure the master cylinder isnt coming through the fire wall.
What makes you think the rod is broken,Seen it visually.
Maybe the retaining clip broke.
And yes the shaft is part of the master cylinder.
