clutch problem =(!!!
i need your help.
i changed the OEM clutch for a exhedy stage 1 clutch and fidanza flywheel. the problem is that before i change the clutch everything was fine, but with the new clutch and flywheel when i drive normaly everything is fine but when i run and the car pass the 5500 rpms i cant shift from 1rs to 2nd gear. but from 2nd to 3rd i can. but in low rpms i can shift.
does any body knows whats the poblem??
also how can i regulate the pedal clutch? is right in the bottom =(
i need your help.
