clutch problem 2.4
Old Sep 25, 2007 | 08:33 PM
black_sheep's Avatar
clutch problem 2.4
noticed the clutch pedal on the car was grabbing really really low the other day. was driving it today through burger king and with the pedal all the way in, the clutch was still engaging. also the car wouldnt shift with the pedal and would only go into the next gear after the rpm dropped to match the engine to the trans. is this the slave cylinder going bad, the clutch, or low fluid. i looked for a resivoir but could not find one
Old Sep 25, 2007 | 08:40 PM
Novajoe's Avatar
your clutch master cyl is connected to your pedal on the firewall inside the engine bay. Check and make sure the fluid is high. If it's low then you have a leak(internal or external). Chances are your clutch master cylinder has gone bad.
Old Sep 25, 2007 | 09:28 PM
isnt the master cylinder for the clutch the same as the brake master cylinder? or does it just get its fluid from there
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
