clutch or transmission?
Old Oct 23, 2010 | 12:31 AM
tidwell.brandon's Avatar
I have a 2006 chevy coalt ss with a standard transmission. while im driving it and i shift geareven if i do it slow andi give it gas it acts like the clutch is still engaged and revs the rpms up alittle then will go its like it has a lag to it. im not sure if im looking at a transmission or clutch problem, it is like the tranny is slipping in a way, at the same time i also have problems getting it in reverse sometimes, and you can hear what sounds like a chattering noise when i downshift to slow down. the car has already had a new tranny put in it after 42k it now has 92k on it and im trying to figure out whats wrong before i lose warrenty, since i had the tranny replaced i rarely dog it out, every once in awhile i will but not often. any input would be great
Old Oct 24, 2010 | 02:50 AM
BlackCobaltsssc's Avatar
Sounds like a clutch to me. I just got a gmpp stage 2 clutch and am very happy with it. heres a link to it and the part number is on the site if you wanted to go to the dealership and order it. Ecotec LSJ Clutch Upgrade Kit 19212712 - Crate Engine Depot
ps this clutch engages at the floor appose to engaging when you are all the way off the clutch which i like a lot better.
Old Oct 28, 2010 | 12:23 PM
MyOtherSS's Avatar
Clutch gets my vote. probably slipping when you get on it.
Old Oct 28, 2010 | 06:34 PM
Gixxercobaltdriver's Avatar
Heres a good way to tell. If it is hard to shift in all gears its the clutch, if its only hard to shift in a single gear is a syncro which is a tranny problem
another thing is if you floor it and the speedo stays still while the rpms climb its the clutch.
another way to tell if it is a clutch problem is if you are at a stop, put it in 5th and slowing let out the clutch and if the car wants to die then its not a clutch problem, if you feel it slipping badly and the car doesnt want to die then its the clutch.
hope it helps
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 28, 2015 01:31 PM
