Code P2096 and 22419
Okay so my car has been acting up the last 3 months and this is it. I have gone to dealership nearly every time I have a day off and its just a temporary fix.
It only happens when cold stat. It idles like it wants to stop completely but after cold up its 100% fine. I cannot think of anything else to replace. Dealer and I have replaced 02 sensors and spark plugs , it runs fine for a few weeks then randomly starts up again. Getting really tired of it.
I have K&N typhoon intake with GM stage 1 sensors, ZZP catted DP , Dejon upper charge pipes.
I need this fixed, so annoying.
What's your coolant temp? It sounds like your saying the car runs ok once it is warm but when its cold it runs bad, right? If your coolant temp sensor is reading cold the car will just dump fuel on start up to get it warm. Check that
My coolant is normal, about 108 to 112. The funny thing is every time I go to take it in, they say it's asking for more fuel than what is needed , therefore the CEL is going on. Every time they clear the CEL (no maintenance) the problem stops for about a week and a half. The exhaust smells funny when its running bad whether its cold start or warm, but I took it in and they cleared the code till my appointment on WED. No problems and exhaust is fine. even cold start is working again
Mine did the same thing this past winter, I would start it and it would like go right into limp mode and sound cammed when it was idleing. So would hook up HPT and it was MAF everytime. But like you said after letting the car get warm and driving it, it would be fine.
Even if it is the maf that's messed up I think his coolant temp is still really low, no?
In his latest post he said it ranges from 189 to 195, which seems to be about normal. My car usually stays right around 194 when driving, but like at stop lights it gets into the 200's...... But yah, like the 108 - 110 tempts seem super low.
car is still under warranty, and I am not gonna buy a new TB. let me know how that goes though, it just amazes me that you can clear a code and it runs like new again
Ahh, I see that now. Guess thats not the problem then.
Actually I pulled my negative battery cable and left it unhook for 2 hours while at work and when I reconnected it all of my codes learned and the cel has yet to come back on.. Runs like **** when it's old but once warm it's fine.. I have replaced the maf sensor, spark plugs, barometric pressure on top of the sc.. So only thing I have not changed is the o2 sensors.. So I am going to try the throttle body under my own suspensions and the lack torque when I'm driving, and the limp mode.. But I will def keep you up to date. If the car is under warranty seems odd they have not corrected the issue..
Thanks, yeah they told me to leave it for a day or two. here we go driving a damn rental again.
OrangeCoba
Sep 25, 2015 06:06 PM
