Cold start
Cold start
It has finally hit below freezing temperature where I live and it did it within a day or so. Since then my car has not wanted to stay running in the morning. It will start but then die. I usually have to do this 3 or 4 times then just decide to give it some throttle which then barely gives it enough to keep running. Is this a computer issue with the choke? it only started doing this when the weather got cold. I have not had a problem with it before.
Check ur secondary o2, probably full of moisture, makes startup like crap for some reason
I had same issue and I cleaned and dried both and it runs perfect and starts perfect in cold now
I will try this. Thanks
Last edited by deereboy4320; Nov 24, 2013 at 10:27 PM. Reason: Automerged Doublepost
Looked for a How To in the forums on cleaning the O2 sensors and couldn't find one. Anybody have one? I'm not very familiar with this car yet.
Take em out, spray with maf cleaner for a bit, wipe off, let dry . That's all I do. If I'm right and its moisture in the secondary, it will come running out. Just spray it and dry it and should he good. I used light compressed air to help get the moisture out more quickly. Do u need to know how to remove the sensors? Get a so2 sensor socket, makes it a lot easier. Secondary is straight forward very easy, primary is kinda tricky to get at, shine light down from top by o2 housing, ull see it. Probably don't have to do primary, I'm pretty sure it's secondary that causes the issue. But I'm not 100% so do both to be sure. If that don't work, then we can help u figure out what's next to try
Thanks for the reply, Tom. I'm not sure where the sensors are located at, is the main issue. I'll check youtube and see if I can find a video of somebody cleaning them. If not, I'm having Pep Boys diagnose the car tomorrow, figure it's worth the $45, and I'll ask them to do it.
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
