Coolant in oil
Old Dec 5, 2014 | 03:17 PM
Cristo SS/TC's Avatar
Coolant in oil
Ok, I have a 09 SS/TC with 33k. Took it to local GM dealer, kept getting low coolant display. They did a pressure check to cooling system and compression checked the engine. No visual external leaks, They put a dye in coolant, topped it off and told me to come back if it gets low. One day of normal driving and got the low coolant warning. Took it back and know they see the dye in the oil. No over heating, no smoke, no loss of power. I read some posts about porous blocks? Anybody know of a TSB about this. I do have an extended warranty. Hope it will be covered.
Thanks, Mike
Old Dec 5, 2014 | 03:20 PM
hawkssoccer11's Avatar
Thanks, Mike
leave her at the dealer thats the good ol porus block lol. more prone to the 09s in eary mileage. gonna need a new motor as the coolant goes into the oil. happened to me went through 1.5 gallons of coolant in 2 days lol. you wont see any signs of it until its pulled apart and the oil is milky it should be covered
Old Dec 5, 2014 | 03:31 PM
umrdyldo's Avatar
I do not believe there is a TSB.
But we have seen dozens of them now.
Find the customer service rep on here. They have helped multiple people.
Old Dec 5, 2014 | 09:57 PM
exninja's Avatar
Lucky you having the warranty. However you may still have a tough row to hoe. Can't remember his name, but someone on here had a heckuva time getting the warranty to cover it but he succeeded. Good luck
Old Dec 5, 2014 | 10:12 PM
LNFTX's Avatar
If your car is stock and still within its extended warranty then I dont see too much of a problem. Some dealerships do suck but some are very willing to help. Sounds like the one you've been to has been on top of it so far hopefully it works out quickly for you
Old May 8, 2015 | 01:39 PM
Update. Finally got my car back in April. Long story short after they attempted to just do the top end. It went back to the shop a week later with same problem and ended up getting the LDK from ZZP. Did not pay anything out of pocket.
Old May 8, 2015 | 02:37 PM
exninja's Avatar
The dealer ordered an LDK from ZZP?
Glad to see you're back in business. Too bad it took so long!
Old May 8, 2015 | 02:53 PM
No. The private dealer I got the car from picked it up and took it to his shop.
Old May 8, 2015 | 04:31 PM
breds2k's Avatar
^Talk about making out like a bandit!!! Ive always wondered what companies will do because I guarantee a LDK from ZZP is cheaper than a LNF motor from GM
Old May 8, 2015 | 05:01 PM
GM dealer = $9500 parts and labor, $4500 for the long block. ZZP LDK longblock $1999 and has higher compression with a bit more HP.
Old May 8, 2015 | 05:16 PM
Seems like you got pretty lucky in a way
Old May 8, 2015 | 06:13 PM
exninja's Avatar
GM dealer prices are insane. They were quoting me like $7500 for a shortblock. I can't remember if that was new or used.
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
