Coolant Temp High.....need help!
Old Feb 2, 2013 | 07:36 PM
victoryredturbalt's Avatar
2008 TC
-Recently i have noticed tthe normal operating temp is running higher than it should be.
-Did some research on css and google.
-Normal operating temp is 88c-92c (or 180f-200f)
-Currently been running avg temps of 96c
-car is approaching 5 years which is what the dexcool is rated for so i changed it today along with the thermostat
-thermostat internal seal was beginning to go looked not so healthy
-mixed myself, prestone gmdexcool 70/30ish mix
heres the issue, its still running out of the 'normal op temp' between 92c-96c (lower than bf as it fluctuates now between 92-96, before it held steady at 96c).
Now im thinking mayb the sensor which monitors the temp is beginning to go and is giving a faulty reading?
BTW the outside temp for those numbers are usually below zero C degrees. (its winter here lol)
Any suggestions or anyone with similar issue and their fix, please post
Thanks everyone!
Old Feb 2, 2013 | 07:44 PM
Sox-Fan's Avatar
Got Brakes?
Shut the heat off. Does it go down fairly soon? If it does stop worrying till spring. I'm noticed that the warmer I turn on my heat the warmer the car runs. It varies 5 degrees F from heater off to as warm as it goes. Damnest thing I've ever seen. I can only imagine that up there the heater hasn't been off since September.
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
