Coolant Temp Reading --- ?
on my gauge cluster, my coolant temperature is all of a sudden reading --- so im thinking the plug came disconnected??? is it only the one plug under the coolant tank? Any info would help thank you
Go to autozone and have your codes read. You'll probably have a P0128 set for Coolant temp below thermostat regulating temperature. That would mean you need a thermostat and to clear the code.
I've ran into this a dozen times.
z28addiction
Sep 28, 2015 12:03 AM
