Coolant Temp Reading --- ?
Old Mar 30, 2011 | 01:49 PM
bboyfreeflow's Avatar
on my gauge cluster, my coolant temperature is all of a sudden reading --- so im thinking the plug came disconnected??? is it only the one plug under the coolant tank? Any info would help thank you
Old Mar 30, 2011 | 02:05 PM
MyBalt10's Avatar
The plug is in the block I believe. Its on the driver side. You will see a black piece with what looked like two wires coming off of it.
Old Mar 30, 2011 | 03:40 PM
stonny9's Avatar
The one on the coolant overflow tank is probably just for the coolant level.
Old Mar 31, 2011 | 08:34 PM
Malaclypse's Avatar
Go to autozone and have your codes read. You'll probably have a P0128 set for Coolant temp below thermostat regulating temperature. That would mean you need a thermostat and to clear the code.
I've ran into this a dozen times.
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
