cooling fans do NOT come on.
i would definitely pay if it actually worked lol you have no idea how much ive missed it working properly... since past halloween lol
LSJ Fan Inop Troubleshooting
This is from the GM Service manual for 2006 Chevy Cobalt I think your 07 but they are both still LSJs
Based on what youve said so far, we can safely skip to step 7 (Sounds like youve already done Steps 1- 6
Step 7: Inspect the ground circuit of the S/P fan relay for an open or high resistance:
Did you find a probelm and did this fix it?
Yes = Step 25
No = Step 15
Step 15: Inspect for poor connections at the S/P fan relay.
Did you find a problem and did this fix it?
Yes = Step 25
No = Step 21
Step 21: Replace S/P Fan Relay
Yes = Step 25
No = Step -
Step 25: Operate the system in order to verify the repair.
Did you correct the condition?
Yes = System OK
No = Go to step 3 (Let me know if you need step 3)
This chart is a little large to put it all on here,
Let me know if you got it fixed or if you need more of the troubleshooting steps
I know you mentioned you chaged the Fan2 and Fan1 relays but I didnt seen
anyone mention the S/P Relay, Schematic does show it connects to the fans.
Yes = Step 25
No = Step 15
Yes = Step 25
No = Step 21
Yes = Step 25
No = Step -
Yes = System OK
Yes = Step 25
No = Step 15
Yes = Step 25
No = Step 21
Yes = Step 25
No = Step -
Yes = System OK
Yes = Step 25
No = Step 15
Yes = Step 25
No = Step 21
Yes = Step 25
No = Step -
Yes = System OK
Your issue sounds mechanical, not electrical. Since you have wired the fans and they work, and your DIC display is working (you are correct in your assumption of how the control circut works), the only thing possible is the PCM not commanding the fans on. Follow that flowchart to find if it works, if that is not helping i'd suggest a coolant flush and then change the thermostat, a partially stuck closed one will let the hoses get warm but not flow enough coolant. Drill the replacement to help in the future.
Just in case: I Looked at the Schematic and tried to give a good discription of whats going on (electrically) with the fans. Even if it doesn't help with the problem, maybe it helps some one ealse who finds this thread with a similar poblem.
Also note: S/P Relay, and Sep/Par repay is the same thing. I believe it stands for Seperate/ Paired as it appears to either seperate or pair the fan operation.
LSJ Cooling Fan Operation:
Based on my reading of the LSJ Engine Cooling Fan schematic
The PCM supplies 2 ground signals to energize the Fan1, S/P and Fan2 Relays.
When fans are off:
PCM supplies no grounds
Relay States should be
COOL FAN1 = De-energized
COOL FAN2 = De-energized
S/P = De-energized
Electricity goes
Nowhere, open circuit
When Fans are in low speed:
PCM Supplies ground to COOL FAN1 Relay to energize relay
COOL FAN1 = Energized
S/P = De-energized
Electricity goes
Through 30Amp Cooling Fan 1 Fuse
Through energized contacts (normally open) of the COOL FAN1 Relay
Through cooling fan 1 motor
Through de-energized contacts (normally closed) Ser/Par
Through cooling fan 2 motor
Ground
When Fans are in high speed:
PCM Supplies ground to COOL FAN2 and S/P Relays to energize relays
COOL FAN2 = Energized
S/P = Energized
Electricity goes
Path 1:
Through energized contacts (normally open) of the S/P Relay
Ground
Path 2:
Through 30Amp Cooling Fan 2 Fuse
Through energized contacts (normally open) of the COOL FAN2 Relay
Ground
When fans are off:
S/P = De-energized
Electricity goes
S/P = De-energized
Electricity goes
Ground
S/P = Energized
Electricity goes
Path 1:
Ground
Path 2:
Ground
The T-stat in this car is not setup for a 180 degree temperature, most newer engines are much higher than that. Higher temps are good for fuel economy and engine wear (look it up), but bad for performance. You are not getting performance sitting in traffic, so it isn't really relevant. If you are racing the car, you should tune, and can use that to lower your fan turn-on points. The fans are plenty strong enough to manage the heat, once they come on the engine cools down quickly.
When fans are off:
S/P = De-energized
Electricity goes
S/P = De-energized
Electricity goes
Ground
S/P = Energized
Electricity goes
Path 1:
Ground
Path 2:
Ground
When fans are off:
S/P = De-energized
Electricity goes
S/P = De-energized
Electricity goes
Ground
S/P = Energized
Electricity goes
Path 1:
Ground
Path 2:
Ground
Checking the PCM should be easy enough. Just take out the Fan1, 2 and S/P Relays, and Check for a ground on the part where the coil plugs in on one side and power on the other. All the PCM does to turn on the relays is give them a ground. But make sure the relays are suposed to be on. (Temp > 230 F)
If you have no ground on the relay coils, check the wiresbetween the relay coils and the PCM.
I find it unlikley that BOTH the High and Low speed PCM relays would be bad at the same time,
however it's not impossible.
help asap please
sorry to bring up an old post but was there ever a solution found in now in the same boat lol. only now im in hawaii instead of texas turbosmart lol. text me at 9039480075 please and thank you!!
Having fun on the H1 I see...
Are you getting code P1258?
I can't find anything that straight out says what an overheat condition is temp wise..
But @ 230 both fans will run on high.
The P1258 Code is an overtemp code that does not trigger till Coolant reaches 262F for 8 seconds. So you still ahve 12F to go if you're just hitting 250F. Is it going down? Or staying at 250? Are you getting any kind of warning lights? I know the H1 "parking lot" can be rough, Iwas there 2001 - 2004 I can only imagine that it's gotten worse. Sitting in traffic with the hot air from the other car's exhaust blowing over your radiator fins doesnt help much either.
If your engine DOES overheat, the PCM will turn off the fuel injectors to 2 cyldiners. This will help reduce engine tempatures.
But check, do your fan(s) come on? High? Low? Both? Does it overheat if you're in a vacant parking lot idleing?
Is your radiator hot to the touch when its been running? Fins free? Clogged?
Yes = Step 25
No = Step 15
Yes = Step 25
No = Step 21
Yes = Step 25
No = Step -
Yes = System OK
Yes = Step 25
No = Step 15
Yes = Step 25
No = Step 21
Yes = Step 25
No = Step -
Yes = System OK
Replaced the coolant temp sensor and still nothing... Left the sensor disconnected for 2 minutes or so and only the driver side came on... I need to test the fans now.
My 2007 Cobalt SS2.4 is running warmer than when I bought it
I recently replaced my serpentine belt as it broke on me now my car runs warmer than when I bought it almost a year ago before it would hold steady a 87 degrees Celsius now it well traveling its between 89 -92 degrees Celsius. And when at lights it heats up to over a 100 degrees Celsius. My fan came on today at 103 degrees Celsius what could be the problem
It might be the thermostat , but make sure the fans work too.
I think mine was a wiring problem... I still wired one fan to a switch so I can turn it on manually, but the other fan is working properly now...
Fans not working properly
yes the fan comes on when I turn the a/c on
[QUOTE=canadianviper;7612567][QUOTE=ItalianJoe1;7612565]103 celsius is about normal turn on if the a/c is off why does it heat up between 89-92 degrees Celsius when driving and over 100 degrees Celsius when stopped at a light or in slow traffic
