a couple of DTCs
Old May 18, 2010 | 07:01 PM
michaeljames1989's Avatar
a couple of DTCs
I have a 06 ss supercharged and my check engine light came on today, and i went to check it with my code reader and got 3 codes, P0068, P0171, and P2228. Does anybody know what any of these could mean?
And on top of that when i turn my car on and while im driving with my windows down i can hear a rattling sound, and while im driving and get between 2000-3000RPM the rattling sound gets louder, and the other day when i turned it on it was going under 1000, and when i would get into 3rd gear it would jerk back.
Would any of this be caused by the cat. converter? help if yall can, thanks.
Old May 18, 2010 | 07:06 PM
lsjwannabe's Avatar
What intake do you have on the car?
My guess is thats your cause on the 0068 and 0171.
Old May 18, 2010 | 07:07 PM
Wolf117's Avatar
pretty sure the p0171 is just from an intake if you have one lol. I dont know about the others
Old May 18, 2010 | 07:16 PM
im not all knowing about cars, but i have a K&N airtake if thats what yall mean, other than that i bought her used
Old May 20, 2010 | 08:26 AM
Coblasts's Avatar
2228 is baro sensor voltage,check the connector and the other 2 could be caused by this.
Did you disconnect any thing under the hood ,if so go back and reconnect them properly.
If you change your own oil it the connector behind the SC thats in the way for changing the oil.
Some people remove it to get at the filter with a extention and the wires can easily be damaged if the connector is not removed.
Check it out for damage ond reseat it.
Old May 20, 2010 | 10:57 AM
yeah Coblasts i change my own oil and i reconnected it, but when i changed it i forgot to hook it back up so maybe that code was from when i changed it and i never erased it but ill go back and have a look at it today anyways
Old May 20, 2010 | 10:49 PM
Coblasts's Avatar
The rattling could be your timing chain tensioner going.
Could still get it done under the power train warranty
Old May 20, 2010 | 11:03 PM
19transam81's Avatar
timing chain tensioner bro. its a big problem on these cars. i had my whole cylinder head replaced.
Old May 23, 2010 | 10:01 PM
well guys, i dont know why i didnt check it out first, but the rattling sound was because my muffler basically became unwelded from the exhaust system, i didnt realize it until i put on the jack and lifted it up, and then when i went to a muffler shop they put it on their lift and the whole entire muffler wasnt attached to the exhaust system anymore, so that problem was solved...now another issue is my cruise control wont turn on, now will that be a fuse or something electrical?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
