06 cobalt ss no start
Okay so a couple days ago we put a new head on the car. everything went on fine and we put everything back on right. We checked the timing and thats good, checked for fuel, air, and spark. Have all of those. It cranks over and sounds like it wants to start but wont. Even replaced the crank position sensor, oil sending unit, and coolant temp. sensor. Any ideas on why it wont start????
did you take the timing cover off when putting the chain back on to make sure it was right on the bottom sprocket? it can be off on the bottom and still look right on the cams
when i did the top end on my lsj i filled the head before putting the hose on, after that just kept filling the pressure bottle and it bled itself over a short period of time. i was a little suprised because i've had other pressure bottle engines and they were a pain in the ass
Now that my Heat exchanger and Lamanova manifold are both vented to the reservoir, it bleeds its self. Never had a problem with the Radiator not bleeding properly. I wonder of some of the bleed ports are getting plugged. It's not a very big opening.
how did you vent your s/c coolant system to the reservoir?i hate the stock filler neck of the s/c coolant system it keeps blowing out when its hot and sucking some air in.
did you T that overflow line off the filler neck into the hose from the bleeder on the engine coolant?
oh i see i thought you had somthing thought up that didnt' invovle the option b
i'll probably break down and buy a option b at some point. i'm wanting 60s and a new tune before anything else
SunburstSS
05-13-2012 01:05 AM
firemanfrank
08-05-2008 12:36 PM
