Cracked tranny casing?
Old Feb 8, 2009 | 02:47 PM
chris88z24's Avatar
OK WTF...
I am lying under my car about to change the oil... checking over everything first for anything out of the ordinary. I notice the bottom/side of my tranny casing is SOAKED with oil, and seems to be leaking What the ****?
Should I bring it to the dealer and see what they say? I know a lot have had to worry about voided warranties and stuff but I was just seeing if this was the issue first.
Pics... is that a crack by the black thing? I felt it with my hand and it sure seems like it...
Old Feb 8, 2009 | 02:49 PM
ls1fbody's Avatar
Haz l33t wheelz.
it's possible. Where is the leak? is it oil, or tranny fluid?
Old Feb 8, 2009 | 02:53 PM
chris88z24's Avatar
Its a dark color. It looks like its leaking from where the axle mates to the transmission (driver side). If the tranny casing was cracked wouldn't I be losing clutch fluid and my clutch would be slipping? My clutch grabs really hard so its leading me to believe the axle seal is leaking. Should be a simple warranted fix (I hope).
Old Feb 8, 2009 | 02:56 PM
ls1fbody's Avatar
Haz l33t wheelz.
no the clutch has its own lines, and the fluid is inside your master cylender. You may just have a bad output seal. If you have a warrenty still, this sounds like something they should take car of.
Old Feb 8, 2009 | 02:57 PM
chris88z24's Avatar
Yeah... its leaking right from where the output shaft connects to the transmission. When I first saw it my heart sank, I was like NOOOO!!
I'll have to hit up the dealer one of these days. No biggie.
Old Feb 8, 2009 | 02:59 PM
ls1fbody's Avatar
Haz l33t wheelz.
doesn't sound like a cracked casing, haha when mine went, i knew
but you never know with a performance vehicle...
Old Feb 8, 2009 | 03:02 PM
chris88z24's Avatar
How would I know if it was cracked? I just took pics im uploadin em now, give me a sec.
And yeah it drives and shifts fine, just scared the **** outta me when I saw the oil. lol
Old Feb 8, 2009 | 03:03 PM
06blackg85ss's Avatar
yeah leaky axle seals are pretty common on these cars. speaking of which I haven't checked mine in a while
Old Feb 8, 2009 | 03:07 PM
ls1fbody's Avatar
Haz l33t wheelz.
^ like pauls says it happens a lot on pretty much any vehicle with halfshafts. Humvees are a bitch about it, the ******* blow a seal every 3k miles like clockwork.
doesn't sound like a cracked case, again, look really closely at it, and then have the dealer check it under warrenty. or a tranny shop.
Old Feb 8, 2009 | 03:14 PM
chris88z24's Avatar
Yeah... my internet is wicked slow, I am going to finish my oil change and I will post the pics when I get back in.
Thanks guys.
Old Feb 8, 2009 | 03:21 PM
nybull05's Avatar
hey man i just was doing the same thing and just noticed it on mine and i had it checked out. it is just the seal.
Old Feb 8, 2009 | 05:21 PM
chris88z24's Avatar
Bump for pics.
Old Feb 8, 2009 | 05:27 PM
nybull05's Avatar
that is exactully what mine looks like. its just the seal, no worries really.
Old Feb 8, 2009 | 05:29 PM
chris88z24's Avatar
In the last 3 pics look by the black cap, to the left of it... doesn't that look like a crack? Or is it just the way the case is casted. Theres oil by it and when I feel it I can feel a bump... but I am not sure. It was soaked in oil, it's only clean because I wiped it up with my finger.
Old Feb 8, 2009 | 05:34 PM
looks more like from the seals man, and they usually don't crack there
Old Feb 8, 2009 | 05:35 PM
EatonTVS07's Avatar
seems to be just the seal
Old Feb 8, 2009 | 05:36 PM
trent_ky's Avatar
better hope your dealer is nice when mine cracked i had to pay for a new transmission out of pocket...
Old Feb 8, 2009 | 05:37 PM
nybull05's Avatar
not really sure man, cant really tell. maybe try and really clean it off and then check it. put i would lean towards there not being a crack
Old Feb 8, 2009 | 06:00 PM
chris88z24's Avatar
Wouldn't the crack be much larger than that? Also if it's cracked there I still am not sure why there is oil above the crack... unless the seal is bad AND the case is cracked
Old Feb 8, 2009 | 07:55 PM
usnsdoc's Avatar
that looks more like casting flash than a crack. besides, the way the fluid is scattered around the shaft would make me think the output shaft seal.
Old Feb 8, 2009 | 08:33 PM
chris88z24's Avatar
I hope it's just that... if the case is cracked and I can't get it fixed under warranty it's either bye-bye cobalt or hello jb weld
edit: did some research, looks like if the tranny casing cracks the fluid leaks onto the clutch causing slip... also leaks where the tranny meets the engine, and not on the opposite side where mine is. Leading me to believe axle seal. Again, clutch grabs fine... no slip unless I make it.
Old Feb 8, 2009 | 08:49 PM
Dainslaif's Avatar
Very confident in voting shaft seal. Warranty should cover that np.
If it was a casing crack it probably wouldn't be that high up. Oil on the side generally means the seal.
Old Feb 8, 2009 | 10:37 PM
chris88z24's Avatar
You guys sure that isn't a crack to the left of that black plug?
Old Feb 8, 2009 | 10:39 PM
68nova200's Avatar
that just happened to my car. it is just a seal.
Old Feb 8, 2009 | 11:02 PM
chris88z24's Avatar
Hopefully just a casting flaw...
