Cracked tranny casing?
Old Feb 8, 2009 | 11:17 PM
usnsdoc's Avatar
want to find out for sure? Get a can of brake clean and spray down the "crack" Im sure you will be able to clearly see what it is afterwards.
Old Feb 8, 2009 | 11:32 PM
chris88z24's Avatar
troof.
However, if it really is a crack, I would be leaning towards a manufacturer's defect and NOT wheel hop related.
Why?
I don't wheel hop my car for one. Even at the track, I don't launch it. I slip the clutch out and baby 1st, then give it all after that. I don't drop the clutch and skip my way down the track.
Second, when the casing cracks from abuse, it cracks inside the bellhousing and leaks fluid onto the clutch, causing clutch slip. I don't have a slipping clutch, nor is the crack inside the bellhousing. Which leads me to believe if there really is a crack, it is a casting defect and thus related to the manufacturer's error and NOT the driver.
Old Feb 9, 2009 | 11:39 PM
chris88z24's Avatar
Phew! Sprayed the "crack" down with brakleen while I was putting my winter rims back on, and it was just a casting flash. I looked closer and its 100% the axle seal.
Warranty time!!
Old Feb 10, 2009 | 06:10 PM
usnsdoc's Avatar
Awesome dude! Glad to hear it!
Old Feb 10, 2009 | 06:29 PM
nybull05's Avatar
Warranty time!!
that is good news man, just wish i had a warranty to get mine fixed
Old Feb 10, 2009 | 06:35 PM
06blackg85ss's Avatar
told ya
Old Feb 10, 2009 | 10:22 PM
chris88z24's Avatar
Originally Posted by 06blackg85ss
told ya
Shhh lol.
I got an appointment at 8am tomorrow for them to look at it... might have to take a TC for a rip to kill some time if they have one there
Old Apr 4, 2009 | 08:09 PM
DoMiStIc_RuSh_06's Avatar
hey man, thats exactly what mine looks like, where the fluid is. So mine should be the seal as well???
Old Apr 4, 2009 | 09:39 PM
usnsdoc's Avatar
More than likely. It is a fairly common concern.
Old Apr 4, 2009 | 09:44 PM
scott allen's Avatar
OK WTF...
I am lying under my car about to change the oil... checking over everything first for anything out of the ordinary. I notice the bottom/side of my tranny casing is SOAKED with oil, and seems to be leaking What the ****?
Should I bring it to the dealer and see what they say? I know a lot have had to worry about voided warranties and stuff but I was just seeing if this was the issue first.
Pics... is that a crack by the black thing? I felt it with my hand and it sure seems like it...
Just replace the seals,all that is , is just the casting its not a crack i bet if everyone looked at their tranny they all would have it.
Old Apr 4, 2009 | 09:49 PM
  #36
Dead Zen's Avatar
tranny seal. im on my 3rd on the left.........
  #37
chris88z24's Avatar
99% sure its the seal bro. Take it in and have them fix it, it takes like an hour to do and is free!
Old Apr 4, 2009 | 09:52 PM
  #38
awesome guys...Thanks for answering my question as well.....
Thanks man, i have an appt tuesday at 2pm. So the will have a look and fix it.....if it is just the seal
Last edited by DoMiStIc_RuSh_06; Apr 4, 2009 at 09:52 PM. Reason: Automerged Doublepost
Old Aug 26, 2009 | 08:22 PM
  #39
northvibe's Avatar
did anyone get part numbers for this? Rallyracer's is leaking and he doesnt have internet at the moment.
Old Aug 27, 2009 | 10:19 PM
  #40
rallyracer's Avatar
Yeah, mine is leaking now
Old Aug 29, 2009 | 08:58 PM
  #41
Mr_Slobalt's Avatar
Overfilling the transmission will leak like that as well. Mine had fluid all over and I panicked that it was a cracked housing, so I sprayed it down with brake clean to check later. Still a leak several miles later. Turned out that I overfilled the tranny by accident. The lift arms were crooked causing my car to lean to the passenger side and overfilling the transmission. lol
I set it on a more level lift and pulled the check/top plug....sure enough, it drained out like crazy! Thousands of miles later it's dry.
Your leak looks like an axle seal.
Old Aug 30, 2009 | 09:58 AM
  #42
rallyracer's Avatar
I just ordered the left seal (GM Part) and after tax it's about $20.00
Old Oct 30, 2010 | 01:51 AM
  #43
a_joyner's Avatar
I noticed a leak on mine in the same area. Does the 5yr/100k warranty cover this, or only the 3yr/36k?
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
