crankshaft pos sensor help?
I'm trying to replace the cps and not sure how to get the starter off. Also will I need have a dealership reset the. Ecu to accept the new sensor? Anyone in phx az and wabts to help ill buy the beer
unhook the battery, thewre are 2 bolts holding the starter in, one at the top of the starter and goes in from the passenger side, the other is at the bottom, its easy to get. unhook the wires and itll come right out, the CPS is held in with one bolt, be carful to pull it out straight or you could risk breaking it off in the block. once reassembled, the code will be cleared because the battery was unhooked, you will be good to go.
getting two codes along with this mess... P1182 and P0068
P0068 Throttle Body Airflow Performance ECM, PCM
P1182 Supercharger Inlet Pressure Sensor Performance PCM
IS THIS CAUSED BY THE CPS BEING BAD? Car drives fine then bam outta no where reduced engine power and just sucks at life... then shut it off and start it ten mins later drives fine then bam.... sucks again...
