crankshaft Position Sensor
Old Sep 11, 2007 | 05:15 PM
luke1987's Avatar
Exclamation crankshaft Position Sensor
I just replaced my crankshaft position sensor and my car is still running bad. like I never replaced the sensor what should I check
Old Sep 12, 2007 | 03:08 AM
Mr_Slobalt's Avatar
sounds like you need a crank relearn
someone should chime in on the procedure
Old Sep 12, 2007 | 03:21 AM
Mnatvyc1223's Avatar
oh shiz, i had this happen to my car, my sensor blew, causing an open in the circuit=bad stuff, my car died just as i was getting off the freeway, took it in had some warranty work they replaced it and now wallah it's as good as new. why dont u have Chevy do it? u still have warranty?
Old Sep 12, 2007 | 08:12 AM
YellowRocketSS's Avatar
ya i had the same problem with my crank sensor that Mnatvyc1223 had with his. I took it to a dealer they put a new one in along with a new catalytic converter cuz that was junk and presto good as new.
Old Sep 12, 2007 | 08:23 AM
NJHK's Avatar
Just curious
Why did you replace the CPS? Were you getting a code showing that or something?
Old Sep 12, 2007 | 09:07 AM
Coblasts's Avatar
Crankshaft Position System Variation Learn
Important: The crankshaft position (CKP) system variation learn procedure is required when the following service procedures have been performed, regardless of whether DTC P0315 is set:
• Engine replacement
• Engine control module (ECM) replacement
• Crankshaft damper replacement
• Crankshaft replacement
• CKP sensor replacement
• Any engine repairs which disturb the crankshaft to CKP sensor relationship
Old Sep 12, 2007 | 09:17 AM
NJHK's Avatar
who was that for?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
