Crankshaft Position Sensor fault
Old Sep 23, 2014 | 03:07 PM
s10novacobaltss's Avatar
Whats this ive seen in a couple threads about the CPU having to relearn after installing a new crankshaft position sensor.
the posts and info ive found is a little old. Wonder if anyone has more recent experience etc.. The car faulted the po335 again today. I unhooked the battery cleared the code with the Torque app and the car started and drove fine and I was able to get home. i got the part the other day even though i cleared it that time also just in case it happened again (like it did today)
Old Sep 23, 2014 | 03:52 PM
mrbelvedere's Avatar
if it needs a crank angle relearn it generally throws that code
Old Sep 23, 2014 | 03:55 PM
Spawne32's Avatar
is this something that generally happens with new CPS's on non E67 ecu's? ive never encountered this and ive had 3 different CPS.
Old Sep 23, 2014 | 04:54 PM
ive seen it on the p12 several times
Old Sep 24, 2014 | 08:43 AM
Not Work Safe relearn
Ok but why would it need a relearn when I havent done anything to it yet..are u saying after I install the part it would need the relearn? Thanks for moving my post BTW.
Old Sep 24, 2014 | 08:50 AM
the machining from block to block and the mass production of the sensors can be off causing the pcm to see a different crank angle vs new sensor
Old Sep 24, 2014 | 12:24 PM
K gotcha..I think..if/when I install new sensor ill do the relearn..a buddy said its outlined how to do in the GM cobalt engine build book..true?
Old Sep 24, 2014 | 01:06 PM
Spawne32's Avatar
i know HPTuners can do it, just did it on my car for ***** and giggles
Old Oct 19, 2014 | 01:33 AM
josh6854's Avatar
Could this relearn cause damage if not done?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
