Creaking noise?
Creaking noise?
So the other day when i got into my car i heard this creaking noise coming from the back, its pretty loud and cant figure it out. I was wondering if anyone had this problem or knows what it is. Any help is appreciated.
I have heard something along those lines before when I got into my car also. It's hard to describe or compare it to anything that I can think of. It doesn't happen very often, but every once in awhile. And when it does that, it'll keep going as long as you keep moving around in your seat a lot. And I also found that if you took the e-brake off, it stops? Not sure if that was coincidence or not though. I have the feeling that we're hearing the same noise. Mine's an 06' 2.4L SS.
Originally Posted by Stevo
Ya its always when i sit down but as soon as the e brake is up it goes away mines a 06' 2.0 ss. Does anyone know what is is???
If you pull up harder on the e brake it shoulds not do it.
The pads are small and operate inside your rear discs like a drum brake.
Nothing to worry about.
i dunno if i worry about it, i had it taken into the dealer to tighten the brake cable, i had to pull the e brake up almost all the way to get the car to hold its spot, now its one click and it holds, not 5 or 6 or 7, and it doesnt creak anymore, well all day today it didnt
Originally Posted by redSS2.4L
So if I take my car to the dealer, they can simply tighten the brake cable that the e-brake uses? Because unless I pull my e-brake AS Far as it can go, it doesn't really hold......(which makes me mad since my 03' Hyundai Tiburon's e-brake worked better, lol).
i just got my car back from the dealer i purchased the car from and now its 1 click and it hold, 2 clicks for a incline. i hated having to pull the brake up 6 or 7 notches. i told them that its a safety hazard and my car rolls from leaving it on a slight incline. they fixed it right away
dont worry, its covered under warranty
Original Hayden Fanatic
if u guys wernt fast & furiousin' it around town yankin on your ebrake it wouldnt have to be tighted...
j/k, i have a creaking noise but it comes from the front passenger side...
had a noise from the right rear of my car today sounded like it was from the rear pillar
didnt hear it all the time finnaly looked under the car and the e-brake cable had came loose from the rubber gromett and was rubbing on the tire put it back all quiet now.
j/k, i have a creaking noise but it comes from the front passenger side...Thread
DANRICKARD
Oct 1, 2015 12:08 AM
