cruise control
Old Oct 9, 2009 | 01:03 AM
der_meister_08's Avatar
cruise control
ok i did some searching and didnt really find anything and if this is a repost im very sorry but i really did use the search and nothing came up
my cruise control doesnt work, but its weird because when i try to activate it sometimes the cruise control on indication comes up in the information center and then goes away in a split second an nothing happens. i read somewhere to lift up on the clutch and see if it comes on (something to do with a clutch sensor) and i tried that still nothing. i cant find a fuse for the cc or anything and im starting to get annoyed lol
please any help would be much appreciated im new to this site and so far i have very much enjoyed my stay
thank you
Old Oct 9, 2009 | 01:04 AM
dunit121's Avatar
u no my car was doing this for a little then one day it worked again
Old Oct 9, 2009 | 01:05 AM
redline4's Avatar
Is your clutch slipping? Because if you have a slight slip in your clutch it will go off too.
Old Oct 9, 2009 | 01:18 AM
no my clutch feels great. the car has 39000 on it too. not that i think that will help the debunking lol
Old Oct 9, 2009 | 01:22 AM
redline4's Avatar
well mine went out at 40k. you may not even feel the slip...Just a thought though.
Old Oct 9, 2009 | 01:27 AM
ok thanks for the info though im just trying to sort out all of the easy stuff first because i live about 120 miles from the dealer and i would rather fix it myself ya know
Old Oct 9, 2009 | 01:29 AM
redline4's Avatar
got news for you though, no need to go to a dealership if your clutch goes out...They won't cover it. But it's probably our on and off switch for the cruise.
Old Oct 9, 2009 | 01:32 AM
blissmaster13's Avatar
You can reset it by taking the terminals off your battery for a few mins. It will reset the system. I had this problem several times and the dealer kept saying that I was pressing the clutch and it was messing up the system (I was not pressing the clutch). They reset the system (I got tired of reprogramming all my stations in the radio) and eventually they replaced the cruise control button and I haven't had a problem since.
I would disconnect the battery first and if it happens again then take it to a dealer.
J.
Old Oct 9, 2009 | 01:35 AM
Acey's Avatar
If you have aftermarket taillight/chmsl bulbs that can stop your cruise from working. Sounds weird but trust me.
Old Oct 9, 2009 | 01:37 AM
yes i am aware of that i was actually talking about taking it to the dealer because of the CC. but i dont think my clutch is worn to the point of replacing by far but you are right and maybe that could be the problem
and i feel like a complete jackass for not at least trying to reset the system. thanks lol
Old Oct 9, 2009 | 01:52 AM
redline4's Avatar
go outside and unplug the battery and in the morning plug it up and see what happens this.
Old Oct 9, 2009 | 02:38 AM
ok il try it out. thanks for the help
and my lights are all stock.
Old Oct 9, 2009 | 02:53 PM
rnjmur's Avatar
this can be caused by a couple of different things:
When the cruise control won't engage, but you see it flash up on the screen real quick it usually means that there is a diagnostic code which is disabling the cruise control from engaging. Not all trouble codes will cause a check engine light. This diagnostic code is set when you 1. ride the clutch (rest your foot on the clutch pedal), 2. You engage the clutch X number of times (I think it is 10 times) without switching gears or 3. The clutch switch is bad.
If you disconnect the battery for 10 minutes then plug it back in and cruise control works, then the code was set due to either #1 or #2.
If cruise control still doesn't work then your brake light switch may not be working (brake lights don't work). Like Acey said, if you put in an aftermarket bulb that isn't right it can cause this issue as well. The cruise control buttons could be stuck or not working right. It could also be the clutch switch itself.
If you haven't changed the bulbs in your tail lights, you can step on the brake and make sure the brake lights are working. If they do work then either it is a problem with the cruise control buttons or the clutch switch. If the clutch switch is the problem you should be able to take the car and have the codes read and look for the clutch switch malfunction code. If it isn't the clutch switch then it is the cruise control buttons themselves, but hopefully it isn't that.
Old Oct 9, 2009 | 03:32 PM
mrader88's Avatar
i have this same problem and the dealer wanted 150.00 to even look at it so i said **** it imma deal with out it. imma go outside right now and un hook my battery and see if that fixes it. i'll hit you guys up on here and let ya know. thanks for the info!
hey guys i just tried that i must not have had the terminals off long enough (5 minutes or so) cuz it did not fix my cruise still flashes its engaged for a split second and then disappears. wierd thing is it did reset my clock but not my stations so im assuming it was not off long enough. ill try again later or after work see what happens....
Old Oct 10, 2009 | 02:45 AM
yeah you should leave it off for at least an hour. im doing it in the morning for a few hours to see if it helps.
you guys have been great thanks
Old Oct 10, 2009 | 03:10 AM
SilverSSyes's Avatar
This has been mentioned before as I have searched for it on this website and found an answer.
Had this same problem 2 days ago, unhooked the battery for about 7 minutes, re-hooked up and we're good to go.
Old Oct 14, 2009 | 07:53 PM
Fidget's Avatar
I tried pulling out the battery fuse for about an hour and had no luck. Where is the switch for the brake peddle? Also would slow brake fluid cause the cruise not to work? I cant live with out my cruise control LOL
Old Oct 14, 2009 | 09:57 PM
rnjmur's Avatar
Do your brake lights work? If they do, it isn't the brake switch. It maybe that the clutch switch is bad. The clutch switch I believe is at the top of the clutch pedal assembly. Just crawl under there and take a look and you should be able to find it.
Old Oct 15, 2009 | 07:53 PM
Fidget's Avatar
Yes the brakes lights work. The clutch switch is the white one correct that is by the clutch peddle?
Old Oct 15, 2009 | 11:43 PM
rnjmur's Avatar
Sounds right. I will look at mine when I get a chance.
Old Oct 19, 2009 | 01:55 PM
Fidget's Avatar
Done worry about it. My cruise control is ok now. I discovered it was the brake peddle that was the issue. I decided to go under the dash and press the brake peddle by and and lift it up back into position. After i did that my cruise control stays on. So for those who are having this problem give this a shot.
Old Oct 19, 2009 | 01:59 PM
Doubletg13's Avatar
unhook both battery terminals and hold them together for 15 seconds. that should reset everything and your cruise control should work. ive done this a few times
Old Oct 20, 2009 | 12:30 PM
09blackonblack's Avatar
to test the clutch sensor push your clutch about halfway down with the car in neutral and try to start it... if it starts then its your sensor if not then your sensor is fine.
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
