Cruise Control Problem
Old Mar 25, 2011 | 11:54 PM
kikal8's Avatar
so.. sorry if this is in the wrong catagory but anyways. im wondering if anybody knows why my cruise control wouldnt be working anymore... it just stopped one day i feel like. im pretty sure it worked after i installed my intake. so idk y it wouldnt work. basically wat happens is.. i turn on the cruise control switch on the left of the steering wheel so it is lit up. then while staying at a steady speed, say 75 mph, i press and hold the set button. just so everyone knows ive used it before so i know how to do it. and it just doesnt do anything. every once and a while while holding the set button i see the hud flash "cruise control engaged" real quick then shut off again. anybody have an idea.
Old Mar 26, 2011 | 12:04 AM
Spoony's Avatar
This problem plagued my 06 Balt as well exactly as you describe...driving down the highway if you mash on the set button I'd see the engaged message flash up but it would never actually do anything, dealer diagnosed it as a faulty clutch switch which was remedied under warranty at the time.
The problem came back the next winter (my cruise didn't seem to enjoy cold weather) but I traded the car in before bothering to diagnose the issue.
Old Mar 26, 2011 | 12:05 AM
kikal8's Avatar
****. haha thanks for the comment man
Old Mar 26, 2011 | 12:17 AM
CTcar's Avatar
Same thing happened to me. Just disconnect the battery for 10 min and that will re-set the computer, and it will work. If it doesn't then it's probably the clutch switch. Do you drive with your foot resting on the pedal?
Old Mar 26, 2011 | 12:18 AM
kikal8's Avatar
um.. for the most part yes. im assuming you mean the clutch pedal
Old Mar 26, 2011 | 12:24 AM
Spoony's Avatar
Driving with your foot resting on the clutch isn't a good idea....
Disconnecting the battery is a good idea, some codes will cause the cruise to malfunction despite the fact that the code has nothing to do with your cruise control (it may be worth getting someone to chuck a scanner on there to see if you have any codes worth knowing about).
Disconnecting your battery won't cause the codes to go away, they'll still be in memory..but the computer should reset and allow your cruise to work (provided the problem is some minor code in the first place).
Old Mar 26, 2011 | 12:28 AM
kikal8's Avatar
i have a code reader. i had a lean code from my intake. i just deleted it. ill try disconnecting the battery tho. thank u guys. i dont have any codes btw ha
CTcar's Avatar
I've read things where the switch just wears out from your foot always resting on the clutch, so don't do it lol. The whole code thing was my problem, and it's also the easiest/cheapest to do so why not
Old Mar 26, 2011 | 12:31 AM
Chevycobaltss3's Avatar
OKKKKKKK THIS WILL BE MY LAST TIME ha ha ha, the reason why your cruise controls quit working is when you have so many cycles of using the clutch like say alot of traffic stop and goes you will throw a cel and it wont work, only way to fix it is to tune it and delete the code from coming on.. I think gm has a revison of the stock tune for it, but im not 100% sure. So its not teh switch thats bad it just a issue the lsjs had.
Old Mar 26, 2011 | 12:33 AM
kikal8's Avatar
so when i get my custom tune it will fix it?... im confused. sorry for the frustration... but, ur saying i cannot fix it unless i get the car tuned?
Old Mar 26, 2011 | 12:36 AM
when gm came out with the car, it wasnt maybe 1-2 weeks later they had people saying there cruise control wasnt working, so gm had to revise the tune on the pcm, and i dont even think that worked, only way to fix the issue that i know of is to tune the cars clutch b circuit out meaning disable it so it dont come on or throw a cel.
btw your color is my favorite car it was my old one. lol
Last edited by Chevycobaltss3; Mar 26, 2011 at 12:36 AM. Reason: Automerged Doublepost
Old Mar 26, 2011 | 12:39 AM
kikal8's Avatar
i know im in love =] and alright man thank u for the help and im coming to u for my tune btw =p. ha i just gotta save a **** LOAD of money before i can .
Old Mar 26, 2011 | 12:42 AM
so what r ure mods gonna be and when you want to lol dude im so tired right now oh yeah i have a guy from wisconnson coming down here this week, he drive a ion redline. Ive been tuning him
Old Mar 26, 2011 | 12:44 AM
kikal8's Avatar
haha it wont be for atleast months from now but weve had this convo before hahaha. i had a thread about it before haha. we had a long convo. i was gonna do the zzp stage 3 and hptuners.
Old Mar 26, 2011 | 12:46 AM
yeah i know lol, i just didnt remember. i am fuc*ing tired im waiting for my wife lol
Old Mar 26, 2011 | 12:49 AM
kikal8's Avatar
ha aw dude i feel ya. im not married but gf always keeps me waiting haha.
Old Mar 26, 2011 | 01:14 AM
BlackARCA06's Avatar
My cruise control switch took a crap, Had to replace it. Was $30
Before I replaced it I had to hit the set button 100 times before it would actually engage.
Old Mar 26, 2011 | 02:35 AM
goeckeritz123's Avatar
So if i went to chevy they would beable to tune it out or no
Old Mar 26, 2011 | 08:55 AM
NCC-2000's Avatar
The reason this problems comes up is because of the way cruise works. As soon as you start to push in the clutch, the car will disengage the cruise if it's working. If you continuously have your foot on the pedal, the car will always think the clutch is in therefore it won't allow the cruise to engage. Simple solution to this is to disconnect the battery for a bit to reset it, then stop resting your foot on the clutch pedal.
Old Mar 26, 2011 | 09:35 AM
^^^^^^^^^ true and not true. . Yes resting ure foot will cause it not to work but the main point is if u let ure car go in so many engaging cycles itll cause it not to work. i mean i am very very umm how do u say ummm ill let other people tell u... When a car see a periodic cycle of clutch engagments while the cruise is engaged itll throw the clutch pedal b circuit code because it thinks the circuit is bad a flaw in early cobalts.
Old Mar 26, 2011 | 10:12 AM
NCC-2000's Avatar
Sounds more like it's just a failsafe feature that's being tripped unintentionally really.
Old Mar 26, 2011 | 10:32 AM
koch1ar's Avatar
Do uhave a bulb out
Old Mar 26, 2011 | 02:28 PM
kikal8's Avatar
Originally Posted by koch1ar
Do uhave a bulb out
?? ha who r u talking to?
Old Mar 26, 2011 | 02:50 PM
BPacak's Avatar
Vtec Rep
also a possible problem. do you have a led 3rd brake light?
Old Mar 26, 2011 | 03:43 PM
kikal8's Avatar
no? aha. i have the stock 3rd tail light and the 4 taillights are the tinted aftermarket ones that use the stock bulb. soo.. idk haha. i dont have any bulbs out..
