Cut off and won't start back
Old Feb 24, 2015 | 05:51 PM
Cobaltblack06ss's Avatar
I was going down the road and all of a sudden my cobalt cut off and wouldn't crank back... It is getting spark & it is also getting fuel... It tries to turn over but just don't succeed.... It is a 2006 cobalt ss.... It's not supercharged....
Old Feb 24, 2015 | 06:01 PM
double clutch's Avatar
Slowly turning over or just a click?
Old Feb 24, 2015 | 07:52 PM
Well it's not just clicking... It's turning over just won't start... It sounds like it is trying to turn too fast?
The code that it is throwing say "P0010"
Last edited by Cobaltblack06ss; Feb 24, 2015 at 07:52 PM. Reason: Automerged Doublepost
Old Feb 24, 2015 | 08:06 PM
http://www.obd-codes.com/p0010
Old Feb 25, 2015 | 12:30 AM
Not too sure about that... What could possibly just make it turn off while driving and then not crank back...? It was running amazing... :/
Old Feb 25, 2015 | 09:56 AM
exninja's Avatar
If you have a p0100 code, first thing to do is unplug the camshaft actuator solenoid valves. Test the resistance across the two leads. If it's greater than 12 ohms, then the solenoid valve is bad. Fix that, clear the code, then try again.
Old Feb 25, 2015 | 10:11 AM
umrdyldo's Avatar
He said P0010 which is the selenoid on the top left side of the valve cover. Intake side i believe. Replace and see if it fixes the issue.
Old Feb 25, 2015 | 10:12 AM
exninja's Avatar
Yes i meant p0010. The test will still work.
Turbo Johnny
Feb 21, 2019 09:41 AM
The Rookie24
Jan 20, 2016 05:14 PM
How to Guide
57
Oct 15, 2015 11:56 AM
The Rookie24
Sep 20, 2015 04:33 PM
bobbob160
Sep 15, 2015 11:31 PM
