damnn brakes
damnn brakes
i own a LS model, so front disc rear drums...i have reason to believe my rotors are warped
would my warranty cover my rotors? i'd prolly need new pads too, its been like this for 1k miles or so
possibly. what are your reasons to believe they are warped? as far as them being covered, depends on the dealer. it's considered wear and tear, but after only 1,000 miles it will depend on how worn the pads are
Why not try posting useful information? Did you buy the car new? Current (TOTAL) mileage? And what exactly is the car doing, and why do you assume it's rotors or that it needs pads? If it's because your rear brakes are out of adjustment, resulting in excessive stress on your front brakes, then you're on your own.
idk why i left the explination out......i bought the car new....current (TOTAL) mileage = 31616, its an '06 btw .....the steering wheel shakes and the car vibrates pretty good...im assuming its my rotors becasue it only happens when im braking hard...as it only happens then....wouldn't i need pads if my rotors are warped from the extra wear or damage due to the warped spot hitting the pad? the pulsating cant be good for any of the other brake parts(cylinder/lines/etc) my rear brakes should be fine, i never touched them
yeah deff. brakes aren't doing it as much now but i know it was alot worse, prolly wore the pads to match the warp haha oh mannn....looks like i'll have to hold off on my rims a little while longer till i can get this problem fixed
yah definitely buy aftermarket.. better and cheaper than GM
thanks ill check em out
i purchased the EBC slotted rotors and the green stuff pads( they were out of the hawk ceramic and it would of been another 2weeks to get em in so i opted for green stuff)
i got everything in over the weekend and i installed them last night to find one of my driver side front studs cross threaded
AWESOME!!!!! made my day....lesson learned, dont let anyone touch ur car even when trying on rims.... im calling those stealerz today and im gunna drop my car off tonight for a new stud
