Day time running lights not working
Please help, I had the projector headlights installed and shortly after my daytime running lights stopped working. figured it was just a bulb so I changed it but to my surprise it did nothing. Now the passenger headlight is completely dead aside from the parking lamp and and the halo rings. I've checked the fuses and nothing was burnt. I've replaced the projectors with the stock headlights, but still no day time running lights. I've also checked the wiring harness and it doesn't appear to be cut into or damaged.
Any help or ideas as to what the problem might be would be greatly appreciated.
Thanks
Shaun
Thanks
Shaun
i've had my projectors for 9 months and the drls on my whole car went out, the speedometer light, and shift lights, and tail light lights went out too...all my fuses were fine too...i havent got it fixed yet though..good luck
Maybe this will help you sort it out.
Daytime Running Lamps (DRL)
The ambient light sensor is a light sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes to the outside (ambient) light level. When the BCM receives this signal, it will either turn ON the daytime running lamps (DRL) or the headlights if the headlamp switch is in the AUTO position. Any function or condition that turns ON the headlights will cancel the DRL operation. With the headlight switch in the AUTO position, the headlights will either be turned ON or OFF, after an approximate 30-second delay depending on whether daylight or low light conditions are sensed. The DRL illuminates the park/turn signal and DRL lamps. The DRL will operate when the ignition switch is in the ON position, the gear selector is not in the PARK position, and the parking brake is released. When these conditions have been met and the ambient light sensor indicates daytime conditions, the DRL will illuminate.
DRL operation in manual transmission equipped vehicles will occur when the ignition switch is in the ON position, and the parking brake is released.
Interior Lighting Systems Description and Operation
Interior Lamps
The interior lamps consist of the following 2 groups. The first group are those lamps which may not be dimmed. The second group includes lamps that may be dimmed.
Courtesy/Illuminated Entry Lamps
This group includes lamps that may be manually turned ON by placing the interior lamp switch in the ON position, or by opening a door.
The dome lamp
The reading lamps
The rearview mirror lamps
The vanity mirror lamps
The dome lamp switch has 3 positions: DOOR, OFF, and ON. When in the DOOR position, the dome lamp operation is controlled by the body control module (BCM). The ON position provides a ground for continuous operation. Ground is provided at G302. The OFF position turns OFF any dome lamp operation. When the dome lamp switch is in the DOOR position, the dome lamp will illuminate when a door is opened. When a door is opened, the courtesy lamps turn ON. After all the doors have been closed, the courtesy lamps will remain illuminated approximately 10 seconds after the last door closes. When the driver places the dome lamp switch in the OFF position, the dome lamp will be disabled.
The inadvertent power control circuit of the BCM supplies battery positive voltage to the dome lamp, reading lamps, and vanity mirror lamps. When any door is opened, the door jam switch contacts close and the door open input to the BCM is grounded.
If the driver inadvertently leaves any interior lamp ON, the BCM will turn it OFF after 20 minutes.
The courtesy lamps will normally turn OFF using the theater dimming feature. The BCM provides a pulse width modulated ground to the dome lamp for the theater dimming feature. The courtesy lamps will also turn OFF immediately if a door lock command is received with all the doors closed, or if the ignition switch is turned to the ON position.
Keyless Entry Interior Illumination
When the driver uses the door key in order to unlock the doors, the body control module (BCM) receives a door unlock signal. The BCM must have inputs that indicate that the ignition switch is OFF, the courtesy lamp switch is OFF, and all the doors are closed. The BCM will then activate the interior lamps. The courtesy lamps will remain ON, approximately 10 seconds after the door is closed. The BCM will then turn them OFF through the theater dimming feature. If the door locks are activated to the LOCK position, or if the ignition switch is turned to either the ON or START position, the courtesy lamps will turn OFF immediately.
On vehicles with a remote control door lock receiver (RCDLR), when the RCDLR module receives a door unlock command from the remote keyless entry (RKE) transmitter, the RCDLR module will send a class 2 message to the BCM indicating that an UNLOCK command has been received. The BCM will keep the courtesy lamps ON approximately 10 seconds and then turn them OFF through the theater dimming feature. If the door locks are activated to the LOCK position, the courtesy lamps will deactivate immediately. When the ignition switch is turned to either the ON or RUN position, the courtesy lamps will deactivate in approximately 1 second.
On vehicles without a RCDLR, when the BCM receives a door unlock command from the RKE transmitter, the BCM will keep the courtesy lamps ON approximately 10 seconds and then turn them OFF through the theater dimming feature. If the door locks are activated to the LOCK position, the courtesy lamps will deactivate immediately. When the ignition switch is turned to either the ON or RUN position, the courtesy lamps will deactivate in approximately 1 second.
Rear Compartment Lamp
The inadvertent power relay also provides battery positive voltage to the rear compartment lamp. When the rear compartment is opened, its switch closes to provide a ground circuit and the rear compartment lamp illuminates. Ground is provided at G401.
Interior Lamps Dimming
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and of incandescent lamps.
Adjustable pedal position switch
Door switches and window switches
Fog lamp switch
Heated seat switches
HVAC control head assembly
Hazard switch
Outside rearview mirror switch
Power sunroof switch assembly
Radio
Rear compartment lid release switch
Rear seat audio module
Steering wheel radio controls
The instrument panel cluster (IPC)
Traction control switch
When the ignition switch is turned to the ON position, the VF displays (radio) turn ON at maximum brightness. When the park lamps are ON and the ambient light sensor indicates low light conditions, all incandescent back lighting turns ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The body control module (BCM) is responsible for the dimming of the interior lights. The BCM receives a varying signal from the I/P dimmer switch. Based on the position of the I/P dimmer switch, the BCM then supplies the appropriate amount of voltage to the interior lamps. When the headlight switch is turned to the PARK or HEADLAMP position, all incandescent back lighting, with the exception of the I/P backlighting, turns ON at the dimming level indicated by the I/P dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting, respond from minimum intensity to maximum brightness in response to the I/P dimmer switch position. The I/P backlight is not integrated in the headlamp switch. The automatic lamp control system must determine if its dark enough to turn the I/P backlights on. Once the I/P backlighting is turned on, the brightness is controlled by the I/P dimmer switch. In rainy weather, etc., the customer may comment that they manually turned on the headlamps, however, the I/P lights did not come on. It is important to note that the I/P backlight will only turn on when indicated by the Automatic Lamp Controls light sensor. This condition is not related to the headlamp switch function, BCM or I/P function. This is considered a normal condition and no parts should be replaced.
Interior Lamps
The dome lamp
The reading lamps
Fog lamp switch
Hazard switch
Radio
I had mine go out but everything else worked perfectly found out it was a melted harness just behind the radiator core support that was the issue. Never blew a fuse just stoped working. Dealer said they had never seen this before and repalceed it and now it works like new.
turns out my problem was with the park lamp fuse, the dealership before they knew what the problem was wanted to not warranty it since i have aftermarket headlights and other things done so i switched back to stock and went to the other dealership across town and got the work done under warranty
OP have you figured out what your problem is yet?
Adam144
Sep 3, 2015 07:48 PM
