Delayed Throttle Response
Old Mar 31, 2014 | 05:09 PM
dtec's Avatar
Hey guys, I drive a 06 ss sc. When im at idle, and I get into first gear to start going, there is a delay when I step on the pedal, the rpms stay the same but the vacuum climbs up to near boost, and then once I step on the pedal a little more the rpms climb and i get going. Do you guys think theres something up with the Throttle Position Sensor. By the way I've had a lean code (p0171) for a little while, incase that might have something to do with it. but i think that might just be a bad o2 sensor. Thanks!
Old Mar 31, 2014 | 05:20 PM
buildmeanempire's Avatar
Clogged cat?
Old Mar 31, 2014 | 05:55 PM
cobaltsssc760's Avatar
how does the car run once you get going???
Old Mar 31, 2014 | 06:13 PM
double clutch's Avatar
Idk how it is with newer cars but with 90s and such, a delay in throttl response was usually linked with a vacuum leak. If ur throwing a lean code then it could be a possibility. Spray some soapy water at gaskets and check for cracks. Hope this helps
Old Apr 1, 2014 | 12:42 AM
dtec's Avatar
Thanks guys, it might be a vacuum leak or a clogged cat, I'm gonna have my mechanic diagnose it.
Old Apr 1, 2014 | 12:46 AM
dtec's Avatar
Good, no bogging or anything.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
