di injectors
Old Jun 1, 2015 | 07:28 AM
tred07's Avatar
di injectors
hi ive searched for an answer to this but cannot find.i am having missfire on cyi. 2 and have done the process of elimination to where i am at point of changing injector.need to know can i just change the one injector with no problems to the rest of them? i bought new injector from rock auto and it came with all 3 seals installed.just hoping to change the no. 2 cyl. injector without having it affect the other 3 in the dismantling process of fuel rail , retaining clips, etc. has anyone done this? any input appreciated thanx.
Old Jun 1, 2015 | 12:47 PM
09CobaltSS1's Avatar
You can replace just the 1 injector with no issues, however, once the other injectors are removed it is strongly advised to replace the seals or you run the risk of compression loss.
Old Jun 2, 2015 | 06:41 AM
tred07's Avatar
thanks for reply 09cobaltss1.let me make sure i understand fully your response, yes it is possible to replace only the #2 cyl injector?so that when the fuel rail is disconnected, the other 3 injectors will not be disturbed? i really only want to deal with the one injector and not have to replace the seals on the other 3. thanx again
Old Jun 2, 2015 | 09:24 AM
exninja's Avatar
When I pulled my fuel real, I believe all of the injectors stayed in the head. It's a very tight fit!
Old Jun 3, 2015 | 05:55 AM
tred07's Avatar
that answers my question fully.thanks to you both!
Old Jun 11, 2015 | 04:12 AM
tred07's Avatar
so we started the disassembly of fuel rail to try and change out #2 injector.we realized soon enough that it is impossible to just change out the one injector with out removing the other three because they are all attached to fuel rail with clips that can only be removed once rail has been taken off of block,and the injectors come out of block attached to rail!so no you cannot just change one injector without disturbing the other three!!so now i have to get seal installer tool and new seals to replace the other three injectors seals just to replace the #2 injector.am i wrong???? also...2009 cobalt ss 2.ol
Old Jun 11, 2015 | 09:12 AM
Grave's Avatar
The clips are just there to support the injectors. They don't hold the injector to the rail. Sometimes the injectors stay in the head and sometimes they stay in the rail.
All of the seals should be replaced.
Old Jun 11, 2015 | 11:03 AM
exninja's Avatar
QFT
When you remove the rail, you'll see that they're more like spacers. Since you're already this far, may as well replace the seals. If the injector comes out with the rail, then they probably needed replacing anyways.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
