Died at WOT and wont start now
Old Mar 22, 2015 | 09:24 PM
  #76
Might be having to hit up mrb soon
Old Mar 22, 2015 | 11:16 PM
  #77
chris88z24's Avatar
Check #4.
Old Mar 23, 2015 | 07:23 AM
  #78
170 and 150 are enough for the car to run
Old Mar 23, 2015 | 09:07 AM
  #79
mrbelvedere's Avatar
take the air intake off and see if he throttle plate is working and try a different pcm
Old Mar 23, 2015 | 12:03 PM
  #80
Okay thanks.
Old Mar 23, 2015 | 02:52 PM
  #81
Would i have to have the ingnition just in the on position to make the throttle move or would it move while cranking?
Old Mar 23, 2015 | 03:17 PM
  #82
chris88z24's Avatar
Just on.
Old Mar 23, 2015 | 03:44 PM
  #83
Sweet thanks i can try that later.
Old Mar 23, 2015 | 04:56 PM
  #84
Terminator2's Avatar
Going to add my vote for ECM or the wiring right near it. I know on the LNFs ECMs water and salt can get past the seals on the plugs and it rots the pins and plug connectors out pretty badly. Not sure if the LSJ can have this issue or not.
Old Mar 26, 2015 | 08:55 PM
  #85
Shipping car to performance autowerks so omiotek can look at it.
And if it dont run after he touches it, look out for a massive part out thread lol
Old Mar 26, 2015 | 10:08 PM
  #86
the blower bearings sounded dry did you relube them after cleaning
Old Mar 26, 2015 | 10:27 PM
  #87
Id have to ask hockeyman, this was his blower.
Old Sep 10, 2015 | 11:49 PM
  #88
ponce7's Avatar
07 cobalt ss wont start
Did you ever find out what was wrong with it ? Having the same problem with my car at the moment when i hit wot im 1st car will bog out and die . i have to doscnmect battery and itll start right up . tppk it to auto zone got the light checked and code was crankshaft sensor so i changed that out today took it around the cornor hit wot car died out now wont start at all !!!
Old Sep 11, 2015 | 11:46 AM
  #89
Oh no! Sounds like grounding to me.
My problem wound up being that i likely went over a bump which caused a loose ground to break and fry the ECM.
Old Sep 18, 2015 | 01:57 AM
  #90
ponce7's Avatar
Okay so im kinda having the same problem at the moment ... Dont know wth it is !! First of car in 1st gear at wot car bogs out at about 5k rpm or so .. Or if i hit a bump or hole on the road rpms drop amd car shuts off ... I replcaes crankshaft sebsor still doing the same . so i took the car to a tuner to get the car reas turns out my pcm is from an 06 malibu... Ivebhad mt car for over a year and it just started giving me problems .. So dont think pcm is the main reason . either way i ordered a new pcm from zzp and 80lbs injectors . before i but everything back on i wanna make sure i wont have the same problem again ... Any ideas of what it could be ???
Old Sep 18, 2015 | 03:18 PM
  #91
07blackg5's Avatar
Slobodan Milošević
sounds like a bad/loose ground to me
Old Sep 20, 2015 | 03:13 PM
  #92
Check all engine and chassis grounds
Old Oct 19, 2015 | 12:39 AM
  #93
firehawk618's Avatar
Crank and cam sensors can be tested without HPTuners or any scan tools.
A decent VOM can test them.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
