Door Doesnt open when unlocked
Old 12-24-2015, 02:08 AM
Mr.SS/SC's Avatar
Question Door Doesnt open when unlocked
So i have been having this intermitten fault for a while and its time for a resolution. So when the door is unlocked the inside handle and the outside handle will not open the door. i have to put the key in the lock and unlock and lock it a few times for the door to actually open. it happens to both doors randomly and you cant open them from inside. so you either have to jump over the seat of Dukes of Hazard it out the window when its not raining. Any ideas?
Old 12-24-2015, 10:00 PM
There are solutions if you search... Ive had the same issue that luckily went away... Basically look forward to taking the door apart and greasing stuff
Old 12-24-2015, 11:40 PM
double clutch's Avatar
Bang around the door handle on the outside. With some luck you may get it open. Then pop off the panels and do some digging
Old 12-24-2015, 11:41 PM
deviance's Avatar
I've had this issue. Ended up using some white lithium grease. Just a temporary fix, sadly, I think you'd have to take apart the door. Or close it harder that helped too.
Old 12-25-2015, 01:41 AM
YelloEye's Avatar
It's a known issue with our door locks and latches, pickup some white lithium grease, take off the door panels, and lube up the lock/latch mechanism.
If it's giving you an issue, you can hit the door near the exterior latch with the palm of your hand to get it to work again.
Old 12-26-2015, 12:20 AM
Mr.SS/SC's Avatar
Thanks guys I will try this.
Feffman
Autocross and Road Racing
02-14-2016 07:52 AM
fonzie1991
02-03-2016 08:07 PM
brandon04
01-05-2016 05:03 PM
spaceagejuliet
12-22-2015 02:48 PM
ssTurbocharged
12-15-2015 09:29 PM
Quick Reply: Door Doesnt open when unlocked
