driver side window problums....
Old Jun 11, 2006 | 07:49 PM
06black's Avatar
Well yet another problum with my car.....every other week it seems.
To day i go and start the car and roll the windows down just like every other day and every thing works fine...
i make the 25min drive to my work and i go to roll up the windows and shut sun roof and all goes to plan EXCEPT my driver side window doesnt roll up.
its acted a little funny sence friday but it always worked so i work in a some what shady place out in pontiac so i try agen and agen and agen to get the window to roll up but nothing works.
so i use my left hand to wigle the window around just trying to make something happen when i hear a "POP" noise so i stop and nothing....so i try to roll the window up while jiggle the window with my hand as best i could when it totaly just breaks and shatters apart INSIDE my door.
so now i'm like WTF what do i do??? i cant just leave the windown down so i drive back home grab the dads magnum and go back to work only to be 30min late due to the drive.
will the warrenty cover such a thing?...i know the dealer has replaced my windshield for free before will they cover this window as well????
I did NOTHING to the window with tools or anything like that...a few shakes with my fingers...nothing extreme.
any ideas or help???
Thanks.
Old Jun 11, 2006 | 08:03 PM
06black's Avatar
come on ya'll
Old Jun 11, 2006 | 08:04 PM
RaineMan's Avatar
Just don't tell 'em that you broke it while wiggling it.
"It rolled down fine, but when I pressed the up button, I heard a pop... and I think it broke."
Old Jun 11, 2006 | 08:05 PM
snobird's Avatar
your insurance should have glass coverage but since something mechanically was wrong i would go down to my dealear and explain what happened the window they wont pay for unless something gm caused which in your case it seemd the window malfuncted but good luck to you in your quest
Old Jun 11, 2006 | 08:12 PM
06black's Avatar
with insurance co's will they make you pay the full deductibul(sp?) for such a thing?
will the warrenty cover this???
Old Jun 11, 2006 | 08:34 PM
06black's Avatar
lol i think thats the thing to do as well...i hope its covered...the problum was a direct result of a manufactureing problum of some kind.
Old Jun 11, 2006 | 08:56 PM
06black's Avatar
bump.
Old Jun 11, 2006 | 11:43 PM
06black's Avatar
tryin agen...bump!
i'm kinda freekin out about this......
Old Jun 12, 2006 | 12:54 AM
Kritter's Avatar
most likely what happened is that the window cam unseated from the regulator. THey are held in by plastic clips, and if that clip broke free of the glass, then what you did by wiggling it was flex the window to much, causing it to shatter...the only other thing I can think of that would cause this is if the glass came free of the vertical track, lined up behind it, thus causing the glass to sit at an angle, which again, would put to much stress on the glass, causing it to break by you wiggling it...If that was theEither way, it is a manufacutring defect, and should be covered under warantee by your dealer, resulting in a new regulator and door glass for you. Your car should only down no more than a day, since to do a regulator/door glass install on these car only takes me 45 minutes or so, but I'm allowing for any cars ahead of yours in the warantee line...Best of luck, have a good one
Old Jun 12, 2006 | 07:23 AM
06black's Avatar
alrite thanks for the info....
I'm headed in to the dealer in a few moments here
Old Jun 12, 2006 | 07:27 AM
snobird's Avatar
insurance companies if you have glass coverage mine has no deduticble for glass but they only pay up to 250 usd so call and ask but dealear should fix since they caused it
Old Jun 12, 2006 | 07:37 AM
patathSS's Avatar
Get it fixed so we can run Wednesday!
Old Jun 12, 2006 | 02:49 PM
06black's Avatar
wensday???
whats goin on wensday?
i forget things wayyyyy easy.
Old Jun 12, 2006 | 11:50 PM
06black's Avatar
well there fixing it under warrenty!!!!
they say it'll prob be wensday before i get it cuz they had to order the glass.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
