DTC P0300 random misfire anyone?
My 2006 ss/sc is throwing a P0300 random misfire code. Has anyone else had this problem? I am taking it to the dealership in the morning for servicing. I was wondering if I should take my CAI off and put my stock intake back on. Any suggestions???
I Get that one from time to time. I just reset it and keep going. Ive noticed I get it more with my interceptors for some reason. YES DEF Take off your CAI, or they will try to say it's causeing it.
If you can, you can take your plugs out and check them yourself, clean them ect.
Does the car seem like its really misfireing? or misfireing bad?
My responce goes to the guy in 2010 that has the problem and took the time to search the forums
I got 42s also, I dont worry about mine. It happens from time to time. I hear it gets worse as you go up in injector size. If you notice the misefires and can hear/feel it in the engine, then worry about it.
Just make sure your plugs are gaped right and clean good
I gapped my plugs at .4. Is that too big?
0.4 is WAY too big,
you need arround 0.040 and 0.042 depending on your year.
Mine are set to 0.040. You sure you didnt mean you have them at 0.04 already? I dont see any spark plug capable of going quite 0.4 (almost half an inch) wide anyway.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
