dtc p0455
Old Jun 18, 2009 | 08:45 AM
mmmrodge's Avatar
dtc p0455
dtc p0455 (large evap leak) cel came on, after a few "check gas caps" messages. brought it to vatozone cleared it, came back ect....
brought it to the dealer, they smoke tested it, zero leaks.
tech pulled service bulletin: to reflash pcm to update.
flashed - stage 2 flash still valid.
tried to charge $70. i us'd them down to $50 and i had a GM care card for $15.
Old Jun 18, 2009 | 12:31 PM
09BlueBaltSS's Avatar
Is your warranty expired? Why are they charging you?
Old Jun 18, 2009 | 12:43 PM
mmmrodge's Avatar
yes. hit 40k on monday
Old Jun 22, 2009 | 07:14 AM
mmmrodge's Avatar
welp light came on again....stay tuned to see which dtc i threw now....f'in pos 4k out of bumper to bumper warranty and starts falling apart....might drive past dealer and look to trade in...
Old Jun 22, 2009 | 07:04 PM
Coblasts's Avatar
The 07 came with the 5 year 100,000 km(60,000 mile) warranty,I kow this because I was pissed when I bought my 06 with a 3 yr 60,000km and they change it a month later.I bought it in june of 06 and in july it was changed.
You better read your warranty material that came with the car.
The only way I could see you having no warranty at 40 k is you bought it used.
Old Jun 22, 2009 | 07:10 PM
Maven's Avatar
Powertrain warranty doesnt cover the ECM.
Old Jun 24, 2009 | 10:33 AM
mmmrodge's Avatar
evaporator canister purge valve solenoid was leaking. replaced under my GMPP majorguard extended warranty that i forgot i had haha....
Old Jul 7, 2009 | 07:35 AM
mmmrodge's Avatar
light came on the third time. brought it to dealer AGAIN. same code p0455. tech found vent valve solenoid to be leaking. replaced at n/c to GMPP warranty. also replaced gas cap with new gm cap.
put about 250 miles on it so far and no light....knock on wood
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Dustonian131
Sep 23, 2015 08:03 PM
WopOnTour
Jan 22, 2015 02:08 PM
X3r0
Oct 27, 2010 08:39 PM
Cobaltss/TC
Jul 10, 2008 12:17 AM
