dtc p0455
dtc p0455
dtc p0455 (large evap leak) cel came on, after a few "check gas caps" messages. brought it to vatozone cleared it, came back ect....
brought it to the dealer, they smoke tested it, zero leaks.
tech pulled service bulletin: to reflash pcm to update.
flashed - stage 2 flash still valid.
tried to charge $70. i us'd them down to $50 and i had a GM care card for $15.
welp light came on again....stay tuned to see which dtc i threw now....f'in pos 4k out of bumper to bumper warranty and starts falling apart....might drive past dealer and look to trade in...
The 07 came with the 5 year 100,000 km(60,000 mile) warranty,I kow this because I was pissed when I bought my 06 with a 3 yr 60,000km and they change it a month later.I bought it in june of 06 and in july it was changed.
You better read your warranty material that came with the car.
The only way I could see you having no warranty at 40 k is you bought it used.
light came on the third time. brought it to dealer AGAIN. same code p0455. tech found vent valve solenoid to be leaking. replaced at n/c to GMPP warranty. also replaced gas cap with new gm cap.
put about 250 miles on it so far and no light....knock on wood
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobaltss/TC
Jul 10, 2008 12:17 AM
