electrical help please
Old Nov 18, 2008 | 09:17 PM
grigs's Avatar
alright so heres the problem... start with the symptoms my interior lights flicker like a strobe.. now my exterior leds on the halos started to flicker but only in one light... getting weird static in random speakers ... rear speakers shut off randomly... jus last night the fogs died but theyre hid ( dont know fi that has anything to do with it) now im guessin its a short but the real question is... where do i look first thanks for any help
Old Nov 19, 2008 | 07:18 PM
Coblasts's Avatar
Check the fuses arent loose,
Also check the Rap relay ,I think its under the hood in the fuse box.It controls all the power.
The only thing that would cause that would be you altenator half cycling so you dont get a clean dc voltage and its getting choppy thus giving you
the strobe affect.
Old Nov 19, 2008 | 07:22 PM
originaladrian's Avatar
first take out every single aftermarket electrical addon you have and try, probably a short caused by something not stock.
and static is from bad grounds. thts prob ur cuase
Last edited by originaladrian; Nov 19, 2008 at 07:22 PM. Reason: Automerged Doublepost
Old Nov 20, 2008 | 12:24 AM
grigs's Avatar
alright so spent the day clearing out all the additional electronics.... the only thing is the sound system which has been in there for 2 years now never had a problem... i did find a fuse for the hids that wasnt just popped it exploded the metal melted into the fuse holder itself .. what would cause a power surge like that...
oh and today i noticed that my interceptor turned off for a couple minutes or so then right back on:S
Old Nov 21, 2008 | 08:39 PM
Coblasts's Avatar
Your Hid must be fried and causing all your problem if they blew the fuse that bad.
They have a ballast dont they to start,it must be smoked(melted and shorting out) or the fuse cant handle the inrush current when you turn them on.
Old Nov 21, 2008 | 08:55 PM
BowTieTillIdie's Avatar
Whats with all these trolling my **** is broke posts. And it is usually something nobody else has go wrong ... I mean that is some weird ass probs if you ask me ..
LOL halos LED's flickering but not the parking lamps LOL UHH OK cuz it runs off the same wires
Hmmmm
Old Nov 22, 2008 | 08:27 AM
Coblasts's Avatar
Hmmmm
The Hids Im sure run off a ballast and when they start going like a florecent lamp they will flicker.And will cause other stuff to because of the start up load of these ballasts.
Has no one ever told you that a florecent light uses most of its hydro when you turn it on.
The Hids work the same way.
And when they start flickering they will heat up the ballast and melt it internally and short out eventually blowing the fuse.
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
09RallyTC
Aug 27, 2015 07:05 PM
juandirtymessican
Oct 27, 2012 10:41 PM
