Engine Power Reduced!!
Old Aug 23, 2008 | 03:44 PM
brett5's Avatar
ok a new problem i was at a light and i opened it up in first and hit the rev limiter and the damn thing went into reduced mode...i shut it down waited a couple min started it again and still reduced mode now my car is sitting...what happened??no smoke no leaking of any kind
Old Aug 23, 2008 | 03:48 PM
twzted's Avatar
your in limp mode
first things first learn to shift...
second disconnect the battery for 5-10min and it will clear...
Old Aug 23, 2008 | 03:55 PM
chris88z24's Avatar
Take your throttlebody off and check those pins inside the electrical connector. I bet one of them is bent and not making a connection. Happened to me, I couldn't figure out WTF was wrong with it until I found that. I drove around in limp mode after I went stage 2 for weeks. It sucked. Also check to make sure that your intake piping is secure (although I don't think this will throw it into limp but check it just to be sure).
Old Aug 23, 2008 | 04:20 PM
brett5's Avatar
well i'm not at the car right now but unplugging the battery did nothing its still in limp mode....
well the tire spun so it hit it and then just died...that shouldn't happen. its a rev limiter...i'm thinking it may be a sensor
cam or crank or somehting
and my car is not under warrenty so what would i be looking at price wise for a new crank position sensor and install if thats what it is
Old Aug 23, 2008 | 04:25 PM
EmperorJJ1's Avatar
have u got the code from an obd2 yet? that will let you know what sensor is broken/ unpluggged
Old Aug 23, 2008 | 04:57 PM
brett5's Avatar
no i i don't have a scanner....i can't imagine what else it may be if something internal broke in would be pouring smoke out the back...so i'd beat on a sensor but how much is theis **** gonna cost me
has anything like this happened to anypne else before and not be able to get out of limp mode????this happened before and then when i shut the car off for 5 min it went away//but its not doing it this time
Old Aug 23, 2008 | 05:31 PM
chris88z24's Avatar
Get the code read and see what it is. Only way we can tell you.
Old Aug 24, 2008 | 01:09 PM
EmperorJJ1's Avatar
when it happened to me a sensor had unpugged. without a odb2 sensor its a million in one shot to whats the problem. Just take the car to an autozone
Old Aug 24, 2008 | 04:04 PM
brett5's Avatar
ok so i just scanned it and its a throttle position sensor is there any easy fix to this or is it shop work..note i have no warrenty
and what exactly is it does it have to do with the throttle body
Old Aug 24, 2008 | 04:14 PM
Sythen1678's Avatar
Check the plug below the throttle body, i just spent 98 bucks from a dealer to plug in my ******* cord....... it fell off twice putting it into limp mode. so wiggle it around and who knows it may start right up.
Old Aug 24, 2008 | 04:20 PM
brett5's Avatar
ok i'll try i hope so i'm not at the car but if that dosen't work what else could i try....the code said low circuit a so whatever that is
is that that big sensor underneath right before the end plate
Old Aug 24, 2008 | 04:24 PM
Sythen1678's Avatar
yeah its the sensor thats a bitch to get too under the throttle body, high rpm's can shake it loose some times worth a try.
Old Aug 24, 2008 | 04:26 PM
brett5's Avatar
ok yea i know what you mean the hardest one to put back on after taking te blower off i'll give it a shot sounds like it may work...and if it dosen't i need a new sensor right???
Old Aug 24, 2008 | 04:33 PM
EmperorJJ1's Avatar
same thing happened here with the same sensor. Just came unplugged
Old Aug 24, 2008 | 04:45 PM
brett5's Avatar
after hitting the rev limiter tho???
that would make sense cause the last time i put that sensor on i don't think i was able to get it to clilck and lock in i remember having to **** with it ok i'll go give it a shot
Old Aug 24, 2008 | 04:50 PM
duke3323's Avatar
From: no longer a kansas member i live in GA ALPHARETTA
wtf my car is doing the same thing it happen last night it wont even go over 45mph it sucks its not even drive able i got passed by a ******* prius man im hurt.
Old Aug 24, 2008 | 04:56 PM
brett5's Avatar
and the car read the code before i even crank the engine...so it may just sense that a sensor is unplugged...but again what if this dosen't work???then what did i do.
Old Aug 24, 2008 | 04:58 PM
EmperorJJ1's Avatar
ya it was loose after we removed it to be ported i guess after a few days of spirited driving (but no wot) i floored it and bamb limp mode. Never hit the rev limiter but im assuming the limiter just helped it fall off/get loose
well try it first.
Last edited by EmperorJJ1; Aug 24, 2008 at 04:58 PM. Reason: Automerged Doublepost
Old Aug 24, 2008 | 09:42 PM
chris88z24's Avatar
Old Aug 25, 2008 | 03:23 PM
brett5's Avatar
ok just want to say thanks to everyone...i popped the hood looked at the sensor connecter and it looked on but i went to go grab it and it just feel right off so i plugged it back in started her up and she's running 100% again
Old Aug 25, 2008 | 04:18 PM
Turbo06Sedan's Avatar
if you scanned the car...did you try clearing it..with the same tool....and driving it?
Old Aug 25, 2008 | 04:22 PM
umrdyldo's Avatar
Good job, glad the internet helped you out.
Old Aug 25, 2008 | 04:34 PM
mperez's Avatar
The Same Thing Happened To Me. It Ran Good For A While But Then Came Back. Turned Out To Be The Map Sensor. This Was 3 Mths Ago. Now Like New
Old Aug 26, 2008 | 03:00 PM
brett5's Avatar
no i didn't clear it...it will clear after driving some much on its own..i always have a cel anyways i have no cat and still didn't put the spacer in yet
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
