Engine power reduced
So i just had my Megan Exhaust system installed today.. everything was fine ..untill tonight.. i was drivin and all of sudden my car goes limp mode..says Engine power reduced.. i could barley get the car to move....so i turned it off..then restarted... it was running fine again but with my engine light on... wtf just happined???
i cleaned it last spring.. it was really dirty... so anyways.. i dissconnected the battery and then reconnected it... engine light went out... went for a drive for liek 10 -15 mins... nothing seems wrong now.. who knows it could happin again.. im going to check my throttle body tomorrow when i can see and reclean if i have to..
i have megan exhaust. there shouldnt be anything like this directly related to the catback from my experiences. best thing to do would be if it happens again, get an obd2 scanner to check out the cel. without that, your guess is as good as anyones on the internet
YOu said this happened after you added an exhsust?
You may need a tune, or something might not be
hooked up. I left something disconected once after
an oil change and I got that.
Check to see what codes you're getting.
Your right,
whats funny is that so many times ive seen threads about CELs and no one gets the codes read and posts them.
If you REALLY want help get the codes read, if you want to go the extra yard, get autozone or adavanced, or use your own scanner and post freeze frame data too.
patooyee
Oct 1, 2015 01:07 PM
