Engine Power Reduced, HELP!
Old Oct 30, 2007 | 09:22 AM
Lewd's Avatar
Exclamation Engine Power Reduced, HELP!
Last night my 06 ss/sc threw a CEL and I noticed that the car would sputter in the higher RPM's. Especially in 2nd gear, at 4000-5000, the car seemed like it had no more power. Maybe misfiring? It would respond when I gave it gas and I tried WOT and the car fell flat on its face at 5500 rpms. Mostly just in 2nd gear though, 3rd had a similar issue but not as bad.
This morning on my way to work i was pulling on the highway and the "Engine Power Reduced" aka Limp Mode came on and the car eventually stalled. I turned the car off and waited about 10-15 minutes. Started the car and drove to work. CEL stayed on but there was power and no limp mode. Still noticed the same hesitation in 2nd and 3rd.
Only Mod is an CAI, and amp and sub in the trunk.
Anyone have any idea what could be wrong? Ive already made an appointment with the dealer but just wanted to ask you guys because I'm kind of a noob and this site is a wealth of information.
Thanks in advance.
Old Oct 30, 2007 | 09:28 AM
justin04's Avatar
my car does this if i over rev... just get out and pull the battery cable of for like 3 mins and go
Old Oct 30, 2007 | 09:29 AM
DoubleLP's Avatar
Still under warranty? Head to the dealer.
Old Oct 30, 2007 | 09:31 AM
justin04's Avatar
its from over revin right?
Old Oct 30, 2007 | 09:57 AM
Lewd's Avatar
Yup still within warranty. Just thought I'd see if anyone here had similar issues.
Well sorta, I over revved last summer, once, and it has been fine ever since. But this happened June of 2006, and i don't remember it happening since.
If this is directly related to over revving is there a quick fix?
I disconnected the battery for a few minutes and reconnected. The car started smoothly and the CEL went off. I won't have a chance to drive it until noon but this looks promising already.
Thanks for your help.
Old Oct 30, 2007 | 10:09 AM
justin04's Avatar
no problem i know my car will do it if i hit the rev limiter hard while racing or really gettin on it
Old Oct 30, 2007 | 10:11 AM
intense_SS's Avatar
check your TPS sensor, did u just change your oil?
Old Oct 30, 2007 | 10:12 AM
justin04's Avatar
where is your tps sensor located?
Old Oct 30, 2007 | 10:16 AM
Lewd's Avatar
Whats a TPS Sensor?
Also, I had my oil changed a few months ago, they reset the computer so it said 100%.
Any chance using regular gas (low octane) had any part in it?
Old Oct 30, 2007 | 10:22 AM
justin04's Avatar
ii think tps means throttle postioning swich so
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
