Engine Power Reduced problem
Old Mar 22, 2016 | 06:53 PM
SSxTc0825's Avatar
Ok so I was leaving work a couple days ago and as I started driving, my car randomly decided to cut engine power. I've never had this problem before and idk why it did it. But I stopped in a parking lot, shut the car off, waited about 5 minutes, then started it back up. No problems. Drove it home and everything worked just fine. Now it's happened like 3 times in a row and only on initial start up. Like when I start it up after roughly 12 hours of down time it throws that code. Shut it off, start it up, like nothing ever happened. I'm getting codes on the dash too. P0171, I know that one. The other ones are for a crank sensor and barometric pressure sensor, but both are only intermittent. P0171 is lean but I can smell gas whenever I put any throttle to it and my AFR is reading normally. I did just put a new longtube on so maybe thats the problem?
Old Mar 22, 2016 | 10:49 PM
Sl0wbaltSS's Avatar
Does SERVICE ESC or SERVICE TRACTION come on at all?
Old Mar 23, 2016 | 04:56 AM
SSxTc0825's Avatar
No. I get neither one
Old Mar 23, 2016 | 02:52 PM
Psykostevo's Avatar
So are we talking about a 2005-2007 SS?
Old Mar 23, 2016 | 04:39 PM
SSxTc0825's Avatar
Yes 06 SS/SC
Old Mar 24, 2016 | 01:24 PM
SSxTc0825's Avatar
Bump, any ideas?
Old Apr 5, 2016 | 01:12 PM
SSxTc0825's Avatar
Update
Ok so I took it and had the codes read. Multiple misfire. I bought ZZP's LSJ coils and put them. Same problem. I put them in and it sounded better so I drove it (after I let it warm up). Normal driving was fine but the CEL started flashing again. I tried it under load at WOT and Engine Power Reduced came on. So I stopped and shut it off. Started it back up and it was fine drove it and it got to about 7 psi and threw it again. Limped it home. I have codes that I need read again. My car sounds like a Subaru. Idk why. It's sounded like that ever since I installed my longtube, 3" catted downpipe, 2.9" pulley and hub, 60lb injectors, dual pass, and tune from ZZP. I'm at a loss and can't risk my car right now. I've read that it could be a blown cylinder?? Please help
UPDATE*****
Codes are p2135 and p1681 or something to that effect. Throttle position and control module not programmed. So I need a new throttle body? I've cleaned mine twice but it still comes up
Old Apr 13, 2016 | 01:55 PM
jdeshong's Avatar
I would do o live scan to see what the fuel trims look like.
Old Apr 13, 2016 | 02:00 PM
This. Its possible that its the tb, but check wiring to tb, map, maf and look for intake leaks as well. Subaru sound is definitely a misfire
Old Apr 13, 2016 | 04:14 PM
jdeshong's Avatar
When my car had a big vacuum leak, it was throwing random misfire & TPS codes along with the lean code. It ended up being a bad evap purge valve solenoid on top of motor & dirty MAF.
Old Apr 19, 2016 | 06:30 PM
SSxTc0825's Avatar
I went ahead and replaced both the throttle body and the evap purge solenoid. I have a question though. The little green bleed cap on the plastic vacuum line; if you open it, should it hiss or vent vapor/fumes? Because I put it on and disconnected the plastic line running from the front of the solenoid to the throttle body and it didn't start acting like it had a vacuum leak. Same thing happened when I opened the little green bleed cap. Could the lines be clogged or something fuel related be causing this misfire? Please help!!!!! I'm going on a month with it like this and drag season is coming up lol
Old Nov 14, 2020 | 02:05 PM
isael872's Avatar
i get that..
i get that esc off.. and engine power reduced..
spacedintime
Jul 22, 2016 02:23 PM
StevoElSupremo
Mar 27, 2016 09:26 PM
SSxTc0825
Mar 27, 2016 12:30 PM
yellow_cobalt
Mar 21, 2016 09:58 AM
