engine problem need advice
Old Aug 23, 2010 | 04:45 PM
bbbevans89's Avatar
http://qik.ly/BDtWkHLcR8UaVnRwqEAgR8p i uploaded a vid from my iphone makes a very bad noise can you help me out. i did the screwdriver trick and it is coming from the supercharger.
Old Aug 23, 2010 | 05:34 PM
quikdcride's Avatar
is it a ticking noise that is present when you start the car when its cold and then goes away in a few minutes once it warms up? if so its the exhaust manifold gasket if not IDK!
Old Aug 23, 2010 | 05:38 PM
gdubs's Avatar
That sounds like a Rod Bearing
bbbevans89's Avatar
its does it at idle and getts louder with acceleration and it doesnt stop at all just found it as i was sitting a idle infront of my house
Old Aug 23, 2010 | 05:42 PM
gdubs's Avatar
That really sounds like a Rod Bearing. If not its def in the valve train. Any problems with losing coolant and or oil?
Old Aug 23, 2010 | 07:14 PM
bbbevans89's Avatar
no i got lots of coolant and i have no leaks on oil or anything i got a pic i can show you if the s/c rotor give me one second
Old Aug 23, 2010 | 07:21 PM
bbbevans89's Avatar
Old Aug 23, 2010 | 07:46 PM
reddevil's Avatar
it sounds like a printing press..
you say it was in the super charger listening ti it with screw driver, pull the sc and replace it..
Old Aug 23, 2010 | 07:56 PM
bbbevans89's Avatar
yea im going to buy a supercharger soon lol it sounds like all **** hell
Old Aug 23, 2010 | 10:39 PM
army_greywolf's Avatar
confirm by taking off serp belt, restart, allow to idle (it'll throw a code be prepared to clear it after the test)
Old Aug 24, 2010 | 01:28 AM
scottie's Avatar
^x2.
Old Aug 26, 2010 | 07:41 PM
bbbevans89's Avatar
did the supercharger was making the noise and ive got a new one coming anyone know a company that can rebuild it
Old Aug 26, 2010 | 07:59 PM
send it back to EATON go to their website it'll take some hunting but either them or one of their authorized distributors can get you a rebuild kit, this is something you can do at your house with basic tools and some time, the gear case cone has pressed in races, find a shop to change those and thats all you need.
Old Aug 26, 2010 | 08:00 PM
bbbevans89's Avatar
thanks
Old Aug 27, 2010 | 07:35 PM
bbbevans89's Avatar
does this sound about right lol i changed my supercharger that i bought from a guy on here he says its got 12k on it.
http://qik.ly/DKkHsuuFq232P6URZRLWIjB
Old Aug 29, 2010 | 03:28 PM
xxxxsh4d0wxxxx's Avatar
Sounds MUCH better. Are you sure it wasn't just a SC coupler. Mine will do that every so often, and I know it needs to be replaced. It's a cheap part. Also I would buy the upgraded timing chain tensioner bolt.
Old Sep 8, 2010 | 07:42 PM
bbbevans89's Avatar
i looked at the inside of the supercharger and you can see where it was rubbing now i have a fuel leak somewhere on the top of the fuel tank
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
