engine reving on it own
Old Apr 29, 2006 | 01:25 AM
CobaltSS-Superchager's Avatar
Some time when my car is idle at a real light, my car is on neutral, and my foot off the gas. The rpm goes up and down on it own, as it the engine is reving on it own. Is that a promblem i should worries..
KIT - providence, RI
06 ss supercharger, victory red. just got it 4/25/06
Old Apr 29, 2006 | 01:27 AM
kadumel's Avatar
Take your foot off the gas? Revving is created when you do this =\
Old Apr 29, 2006 | 01:29 AM
inhale's Avatar
i had that problem and it went away. others have had that problem and took it to the dealer. the dealer just reflashed the computer and all was good
Old Apr 29, 2006 | 01:31 AM
I said early my foot was off the gas..
Old Apr 29, 2006 | 01:33 AM
So it something i dont really have to worries about ??? I guess the engine is just breakin itself in. Still under 500 miles..
kadumel's Avatar
No check again, you said your foot was ON the gas...
Old Apr 29, 2006 | 02:24 PM
tiny's Avatar
are you serious?
Old Apr 29, 2006 | 02:26 PM
kadumel's Avatar
Originally Posted by tiny
are you serious?
Nah the post was changed post facto, it said his foot was on the gas, then when I quoted it said of the gas, then finally it was fixed to say off... Nice try tho, look at the quote in my post to see the secondary quote
Old May 1, 2006 | 09:48 AM
l Sh1ft l's Avatar
Had this problem in my old car. Was veryy annoying and i'd imagine not good on gas. I installed my intake and kept the battery off for awhile and it stopped. Reflash would probably fix it.
Old May 1, 2006 | 11:09 AM
juststickit124's Avatar
Hey I have a thread titled "Unknown Problem please take a look" It sounds like you have the same issue, read the thread it may help. However, people suggest to have GM reflash the ECU, I took mine in friday and they refused to reflash it. They said there wasn't a problem and the lastest software is in. I argued for about a half hour, and left without a reflash! It doesn't really cost them anything, just download a program and leave it alone for a little, it sucked but whatever, if the car dies it's under warranty. Hope the info helps!
Old May 1, 2006 | 09:21 PM
Blown 4-banger's Avatar
when it does it is your a/c on? I did it to me with the a/c on (one and only time a/c will ever be on) but if I rev mine it comes back to about 1500 and sits for about 1/2 second, is that what yours is doing?
Old May 1, 2006 | 09:25 PM
Brian MP5T's Avatar
Is the A/C or defrost on?
Old May 1, 2006 | 09:34 PM
Xenozx's Avatar
Does it start out of no where or does
"slowing down, put the car in Neutral and before the car fully stops the RPMS go up and down"
If the above is happening I had this problem and just taping the gas got rid of it. its a known issue, and Never went away until after I had Stage 2 installed. I think it has something to do with how low the SS stock idles. With stage 1 I Idled much higher and was much more secure.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
