Engine ticking ...
Old May 11, 2009 | 07:37 PM
ziggity's Avatar
Engine ticking ...
Ive heard it before but only happens every once ina while ... i was driving today then stoped and it started ticking in and out then started it back up and didnt do it anymore. Then a little while later i was driving for a bit then stoped and it started doing it again. Any idea what it might be? I want to bring it to the dealer but if its not making it when i do then theres no point.
Old May 11, 2009 | 07:38 PM
camshaft343's Avatar
Are you positive its coming from the enigine? Cuz we all know cobalts come with a troll in the trunk. Is it a ticking or more of a knocking?
Old May 11, 2009 | 07:51 PM
ziggity's Avatar
Nah its deff coming from the engine .. more of a ticking ..
Old May 11, 2009 | 07:53 PM
Switt23's Avatar
Check your oil... is it still thick or is it like water and runny.
Old May 11, 2009 | 07:57 PM
rhanes216213's Avatar
I have had a ticking sound ever since my first oil change. It is a lifter sound. I have taken it back to the dealer three times for this sound and they tell me that it is normal. Not normal on any engine that I know of. I know solid lifters do make a little noise. The oil level is fine. It been there two year now.
Old May 11, 2009 | 08:00 PM
ziggity's Avatar
Yea its deff not normal lol it only happens every once ina while tho im thinking timing chain not sure tho .. oil should be good just had it changed 2000kms ago
Old May 11, 2009 | 08:05 PM
Trae's Avatar
I've got something that sounds much the same, only noticed it after i took off the engine cover and installed an Injen CAI. Possibly the throttle body?
Old May 11, 2009 | 08:08 PM
ziggity's Avatar
Yeah I want to get rid of it it sounds like a diesel when its ticking lol can ya upload videos or sounds onto this site?
Old May 11, 2009 | 08:30 PM
rukkee's Avatar
I would bet the timing chain tensioner is giving up.
Old May 11, 2009 | 08:33 PM
ziggity's Avatar
I guess if i brang it to the dealer and it wasn't making the noise there wouldnt be much they could do right?
Old May 11, 2009 | 11:15 PM
SEMAJ07's Avatar
QFT! good luck at the dealership...mine tells me im crazy so mine is going to my actual mechanic to have it done right
Old May 11, 2009 | 11:19 PM
trent_ky's Avatar
you dont have an lnf (ss/tc) do you? if so its the direct injection
Old May 11, 2009 | 11:24 PM
j27's Avatar
j27
I know that my injectors make a lot of noise on start up in my 2.2 when you rev it does it go away?
Old May 11, 2009 | 11:27 PM
hilty003's Avatar
thats what i was thinkin as well
Old May 11, 2009 | 11:31 PM
SEMAJ07's Avatar
i checked his profile...he has an 07 ss/sc...it seems the timing chain tensioner bolt is a problem with some early 07's (including mine) and i believe 06 models.
Old May 12, 2009 | 02:16 AM
ziggity's Avatar
Yea i have an s/c ... when I just got home before and let it idle for a min it did it for about 30 seconds then went away ... i never hear it while im driving or rev it up though
Old May 12, 2009 | 11:02 AM
trent_ky's Avatar
my car makes a noise that sounds like marbles in a coffee can (kind of) sometimes when idleing but its not very loud...i just assume its the supercharger and forget it lol
Old May 12, 2009 | 03:33 PM
ziggity's Avatar
Nah this sound is loud as hell sounds like a pos when it does it lol so if it was the timing chain why would it only do it at idle?
Old May 12, 2009 | 03:48 PM
07SCblackSS's Avatar
Mine kind of did this, and they replaced my supercharger and it was fine for a little while, now 7k miles later (26k total) its doing it again. But I'm almost sure my ticking was from the charger
Old May 12, 2009 | 07:53 PM
rukkee's Avatar
At idle there is more slack in the chain than under load or at higher rpm. The tensioner is fed by oil and oil pressure is it's lowest at idle aswell.
Old May 12, 2009 | 11:51 PM
xxxxsh4d0wxxxx's Avatar
I don't know about the OP's exact problem, but on my 2.2L, and everyone else I know with one, the injectors tick loud as *****.
Old May 13, 2009 | 12:01 AM
golden chicken's Avatar
"it sounds like a diesel"
that's exactly what mine sounded like. it's the timing chain tensioner.
i always heard it at idle on a hot restart--that is, drive, shut car off for 20 mins, then drive again.
Old May 13, 2009 | 05:47 PM
ziggity's Avatar
Yea mine only does it when its hot to .. did you end up getting it fixed?
Old May 13, 2009 | 08:43 PM
yup. i fixed it myself. the part is about $60 on CED. you need to take the valve cover off and get a 32 mm socket to get the old tensioner off and install the new one. you install the tensioner in its compressed state and release it by striking the tensioner guide from up top. that's why you have to take the valve cover off.
don't listen to people who say you don't have to take the cover off and just start it up and let oil pressure release the new tensioner, unless you want to risk the chain jumping while it's slack. it doesn't take long to take the valve cover off.
Old May 13, 2009 | 10:09 PM
ziggity's Avatar
Yeah i still have warranty so I might bring it to the dealer but I dont think they'll just do it unless its making the noise .. can this cause any damage if I don't get it fixed?
