Evap Problem
Evap Problem
I've heard of multiple things about the evap problems and was reading and i was talking to a dealership and they said that fuel system isn't covered after 36k miles...is this true? I was sreading about the emission equipment warranty and it talks about 50k miles.
And if they are lying how should i approach them when they tell me that again?
Also im getting a too lean code too and only thing i have is the CAI. But Im not sure whats causing it. I've clean the MAF multple times and its clean. A guy across the street said it was running leaning as well.
Reset the PCM.
Disconnect the battery for 10 minutes. Put it back on the terminal. Start the car and let it idle for 5 minutes, no throttle.
The car will relearn the perimeters and it should be fine.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
