Everyone's help is needed ASAP
Old Sep 29, 2010 | 07:13 PM
LARGEsuperchargeSSSC's Avatar
Hey everyone. So i've recently replaced the fan assembly, radiator, condenser, and intercooler on my 05 ss supercharged. The car still won't start. It started a few times but it took a while to start it. A friend said he thought it could be a fuel problem considering the cars been sitting for a while before any work has been done to it. I replaced the oil and the oil i took out was a normal caramel color. As of now, the cars sitting in the shop. Any ideas on what i could be dealing with?
Old Sep 29, 2010 | 07:16 PM
RecklessL61's Avatar
starting, the car only needs 3 things fuel, air, and spark check to see if you are getting those things if you are not then that is your problem, if its not one of thoses then it may be a sensor but i dont know what sensors on these cars will keep it from starting, i have yet to find one that will
Old Sep 29, 2010 | 07:19 PM
one thing to check is to see if the fuel pump cycles up when you turn the key
Old Sep 29, 2010 | 07:24 PM
nicksredline's Avatar
so did it start before u said i changed these...was thre a reason for the change... i beleave a crank sensor would keep the car from starting or you need to crank for well over the aloted time you would usualy crank ( hold the key for like 30-40 seconds and if it starts its the crank or cam shaft sensor.) these cars have a problem whn they get cold the ignition switch stops working but after some time it should work after u try it and wait like 30 mintues... more info on what its doing... is it turning over? is it just not doing anything? what happened that u needed to replace all the front end condensors and everything?
Old Sep 29, 2010 | 07:26 PM
as stated abbove check the fuel pump ... check for fuel pressure at the rail by pressing the releafe valve and then cranking and pressing it again see if there is pressure both times or even use a fuel pressure tester. next thing on the list is making sure ur starter is in working order ... but i need more info to determin what could bne the problem
also "sitting for a while " as in how long? a year...maby u got bad gas.
Old Sep 29, 2010 | 07:31 PM
thc's Avatar
thc
if you crashed it you may need to reset the inertia switch?
Old Sep 29, 2010 | 07:34 PM
army_greywolf's Avatar
ding.
Old Sep 29, 2010 | 08:34 PM
damien's Avatar
Inertia switch?
Old Sep 29, 2010 | 08:48 PM
thc's Avatar
thc
Originally Posted by damien
Inertia switch?
spelling may be wrong .but , cars have a safety switch to cut the fuel when your in an accident . not sure where it would be on the cobalt. im wondering if im going to have to do this when i try to start mine this week
Old Sep 29, 2010 | 09:50 PM
Yes, the car when in an accident. I'm not sure how long it sat because I purchased it with a salvage title. Where is this inertia switch, because that may be my problem considering it was in an accident. The car will crank, and it started two or three times after it cranked for a while. Now it just will not start. I had to replace the condenser and all that because it was in an accident. Something had hit the front assembly, damaging only the radiator, condenser, a/c fan, and intercooler. It missed the front bumper. Thanks for your help, and I'm anxiously awaiting your replies.
Old Sep 29, 2010 | 09:53 PM
Pedobear's Avatar
its in the most difficult spot you can possibly imagine....
actually im not sure where its at but knowing GM its a good guess
Old Sep 29, 2010 | 10:13 PM
its not the intreia switch because he said it started before, and the accedent didnt sound bad enough to cause it to go off, the car will start with out either or crank or cam sensors plugged in you just have to have one plugged in for it to start,
Are you sure everything is plugged in, the throttle body, mass air flow sensor, ever thing. Also depending on how long its been sitting it defantly could be bad gas, If you have a code scanner plug it in and see if theres any codes from when it did start, mabey like a P0300 which would be random multipule missfires which would indcate bad gas,
Old Sep 29, 2010 | 10:15 PM
if you not the machanic type i would tow the car to the dealer and see if they can figure it out, they should only charge like 100 bucks to tell you whats wrong, then you can take it home and fix it yourself
Old Sep 29, 2010 | 10:16 PM
Pedobear's Avatar
wait this is SSSC what about the SCIS sensor on top of the supercharger, a friend of mine had his blown off for some reason it wouldnt start
Old Sep 29, 2010 | 10:19 PM
I know nothing about that i have a 2.2 so we just use that sensor to plug that whole lol
Old Sep 29, 2010 | 10:25 PM
Pedobear's Avatar
the SSSC sensor on the top of the supercharger has a function it is a 1 bar sensor except IIRC it was not a MAP but a SCIS sensor.... dont quote me tho. im starting to lean toward a messed up sensor
Old Sep 29, 2010 | 10:27 PM
Where are these sensors?
yea it could deff. be that sensor im not sure if that would keep the car from starting
like i said when super charging a 2.2 we dont use that sensor so i would never have to worry about that
Old Sep 29, 2010 | 10:29 PM
Pedobear's Avatar
nope you wouldnt have it not plugged in lol.
the fuel pump fuse could be blown. i pull mine when i changed the fuel filter to depressurize the system.
Old Sep 29, 2010 | 10:30 PM
i'll have to tell you what codes came off of it tomorrow. Thanks for your help so far
Pedobear's Avatar
^ ill check in then
Old Sep 29, 2010 | 10:38 PM
i will also check again tommarow
Old Oct 3, 2010 | 09:18 PM
So, it turns out that after all this i need a new engine. I was told coolant was leaking into the engine, so they need to replace the entire thing.
Old Oct 3, 2010 | 11:38 PM
Does anyone know anyone trying to sell a 2.0 l lsj engine? or a good place to buy one?
Old Oct 3, 2010 | 11:44 PM
paintballerr78's Avatar
you can try morad
http://cgi.ebay.com/ebaymotors/Cobal...Q5fAccessories
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
