First post and first problem
Old Mar 1, 2009 | 05:21 PM
2MCHBoost's Avatar
Hey guys. I'm having a major issue with my irl. The car will perform fine for the first 5 minutes and then the low power light will come on and the car becomes super sluggish. If i turn the car off the car will return to being fine then 5 minutes down the road it starts all over again. I had some bad gas awhile ago and thought my problems were over but i don't know whats wrong. Fuel filter clogged because of the bad gas? Anyone have any idea's? I'm going to tow it to the dealer on Tuesday if i can't figure it out. Thanks
Old Mar 1, 2009 | 05:29 PM
BigTizzle903's Avatar
#4??
Old Mar 1, 2009 | 05:30 PM
Jn2's Avatar
Jn2
check EVERYTHING in the engine bay, make sure intake is not clogged with something, replace fue filter, check spark plugs, what CEL comes on?
Old Mar 1, 2009 | 05:32 PM
I'd also do a compression test.
Old Mar 1, 2009 | 05:34 PM
boostedss26's Avatar
check fuel pressure
Old Mar 1, 2009 | 06:12 PM
2MCHBoost's Avatar
Originally Posted by BigTizzle903
#4??
Originally Posted by boostedss26
check fuel pressure
Would like to add the car is completely stock. Going to change the fuel filter and plugs tomorrow. Thanks for the quick reply's
Old Mar 1, 2009 | 09:14 PM
DarkSergeant's Avatar
It's an Ion Redline?
Edit- read over that part in your post.
If it's an 04, it's not other warranty, right? You might have more luck with a local mechanic you trust.
Maybe battery/alternator/coil packs/plugs..?
I'd def change any filter you haven't changed since the bad gas incident, especially fuel filter.
Might also try just unhooking your battery, draining the power, and rehooking everything. Sometimes that fixes weird ****.
Old Mar 1, 2009 | 09:16 PM
Mnatvyc1223's Avatar
IRL
Ion RedLine
Old Mar 1, 2009 | 09:17 PM
Hockeyman's Avatar
throwing any codes?
Old Mar 1, 2009 | 09:19 PM
Originally Posted by Mnatvyc1223
IRL
Ion RedLine
Ha, yeah. I totally read over that the first time.
Old Mar 1, 2009 | 09:36 PM
Sharkey's Avatar
if the engine power reduced light is comming on its gonna have a code for something. take it to a shop (or autozone) and have then scan it, find out what code it has and go from there.
Old Mar 4, 2009 | 05:26 AM
2MCHBoost's Avatar
Thanks for all the replys guys. I'm having it towed to the dealership tomorrow to see what is up. Thinking about just fixing it and trading it. I need something with a warranty
dennis69
Oct 20, 2015 07:39 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
