Flashing CEL
Old Dec 15, 2009 | 07:13 PM
LsBro07's Avatar
Angry Flashing CEL
Had this problem for over 3months already, took it to the dealer twice! quick run down,
98% of the time, takes me 3trys to start the car, which i have to add gas to start it up, & if it starts up, it sounds like a QUAD ! not power at the crank what so ever,
when i went to the dealer they replaced all listed below..
The first time i went they replaced--
Fuel Module Assembly
IGN Module
Spark Plugs
Still was misfiring & no power at crank sometimes..
The second time i took it they replaced --
P0606 ECM Condition
Replace PCM. as well as perform crankshaft off set releran procedure
interal failure of ignition module-replaced
battery
& starter drags, may have bad starter Which they didnt bother to replace..
Results,
Still misfires, doesnt start up, No power..
takes 3-5tries to start now, need to add gas also..
Any ideas on what may be causing this? im sick of going back and it not being fixed
Old Dec 15, 2009 | 07:29 PM
Maven's Avatar
Well the flashing check engine light just means massive misfire(catalyst damaging levels of misfire)
Is it only seeting a P0300 or is setting indvidual codes? (301, 302, 302, 304) Does it set any other codes?
My first guess would be that its not actually a failure but a bad connection at the ICM. It could very easily be a coil assembly.
Old Dec 16, 2009 | 12:28 AM
LsBro07's Avatar
il ask the dealer tomorrow, im taking it back in the morning
but they honestly suck at finding out whats causing this
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
