FML!!!!! big problemm
Old May 17, 2011 | 07:25 PM
Tcobalt421's Avatar
Thumbs down FML!!!!! big problemm
okay so i was going to my cousins communion on saturday and was somewhat running late, so as im in front of my girlfriends house waiting for her to come out to pick her up and go to the party, i am trying to put my gold bracelet given to me by my gf as an anniversy present on with one hand(PITA) neways, as im trying to put it on after about a minute or so the bracelet slips from my hand and falls by the seat and the metal column where the seat travels on if you move it back and forth. so im trying to get it and all of a sudden it falls through a small crack another 3-4 inches down past the carpeting and is laying on the frame it looks like!!. i don't think it can fall out of the car and i was so pissed when this happened. looks like ill have to take my front seat out and the bracket that the seat moves on to get my hand or some sort of tool in to grab the bracelet. i am so pissed and this is just my damm luck, is the front driver's seat hard to take off? FMLL
Old May 17, 2011 | 07:31 PM
DBlock's Avatar
QUEEF-NUGGETS
wow that sucks bro,hope you get it out.
Old May 17, 2011 | 07:34 PM
kxrida2000's Avatar
Front seat is two bolts and a plug..takes like 5 minutes Max
gotboost?17's Avatar
Nothin Stock
that sucks, but gives ur car a lil more value lol
Old May 17, 2011 | 07:35 PM
user 70823082's Avatar
No, there's two bolts on the back side of the seat. take those out and then lean the front seat forward and take the front rails out of the grooves and off goes the seat. But before you pull the seat completely off there is a plug under the seat that needs to be unplugged.
Old May 17, 2011 | 09:37 PM
Tcobalt421's Avatar
thank you guys for all of your help ill let you know how it goes
Old May 17, 2011 | 10:28 PM
It shouldn't be too hard. You could maybe find one of those magnets that is used to grab bolts, screws, etc from tight spaces. Actually I don't even know if that will work on gold, will it?
Old May 17, 2011 | 10:37 PM
BooSSted's Avatar
That's more of an annoying inconvenience than a problem, haha. You'll get it out, just gotta dig for it.
Old May 17, 2011 | 11:53 PM
rephrase's Avatar
No, Gold isn't magnetic.
Good luck OP
Old May 18, 2011 | 12:08 AM
Tcobalt421's Avatar
thank you!
Old May 18, 2011 | 07:38 AM
Ok, well OP try to hook it with a wire hanger or something.
Old May 18, 2011 | 05:30 PM
Tcobalt421's Avatar
does anybody what kid of tool and size i would need to pop the seat off with>??
Old May 18, 2011 | 06:16 PM
kxrida2000's Avatar
15 mil socket..its not a hard job lol
Old May 18, 2011 | 06:33 PM
O9cobaltSS's Avatar
wow what luck you have lol
Old May 18, 2011 | 10:35 PM
Tcobalt421's Avatar
i know ur telling me!! lol
Old May 21, 2011 | 04:28 PM
Tcobalt421's Avatar
what kind of tool do i need to remove these bolts that hold the seat on. a lug wrench or?someone please chime in
Old May 21, 2011 | 04:29 PM
Just a regular socket wrench.
Old May 21, 2011 | 04:33 PM
Baltbitch's Avatar
Residental Bish.
if all else fails message outtamymind. I'm famous for losing jewlery wasted as **** in his car. He always eventually brings it back to. He's basically pro at it now.
Old May 21, 2011 | 04:34 PM
Where exactly did it fall?
Old May 21, 2011 | 04:39 PM
outtamymind's Avatar
sounds like it fell under the carpeting through one of the wiring harness openings. use a 15mm socket to remove the 2 bolts and tilt the seat forward, unplug the harness and it should come right out. you'll then have easy and full access to getting your bracelt back.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
