Front Brake Squeal
Old Feb 22, 2010 | 01:47 AM
kissrocker52's Avatar
Front Brake Squeal
Ok so i have searched and i cannot find an answer ok so heres the story:
On my way home tonight and this jerk cuts me off and then slams on his brakes so then of course i have to slam on mine so i dont hit him. but now as i drive my front passenger side brake is making a squeak noise as if there is one spot that is rubbing the calipers. Is this common or did something else happen? Is there anyway to get rid of this?
Thanks Guys
Old Feb 22, 2010 | 01:48 AM
EXsoccer1921's Avatar
check your pads, they may just need to be replaced... brake pads have a metal tab to where when they get too worn off it'll start rubbing on the caliper(not damaging) and it'll squeak
Old Feb 22, 2010 | 01:50 AM
ok that is what the first thing i was going to do tomorrow. How much is a decent brake pad set
Old Feb 22, 2010 | 11:19 AM
bump anyone else know what this could be
Old Feb 22, 2010 | 11:47 AM
blackbolt89's Avatar
pads are like 65 bucks for a good set.
Old Feb 22, 2010 | 11:48 AM
for all 4 or just the fronts
Old Feb 22, 2010 | 12:02 PM
just the front. lol. but thats for like ceramic pads.
and wow i just noticed that autozone stopped carrying real name brand brake pads.
i dont want your no name **** duralast brand.
i know you can get hawk pads somewhere online for about 65.
Old Feb 22, 2010 | 12:54 PM
Fishers24's Avatar
has any one still had problums with their breaks squelling even after the new pads and rotors have bin in place 4 over a month front and rear..
Old Feb 22, 2010 | 01:12 PM
ok so as i was driving today the only noise is while i am driving and then just as i tap the brake but then when i push the brake pedal harder it stoprs making the noise could that still be the pads
Old Feb 22, 2010 | 01:20 PM
yeah those sound like the wear indicators on the pads. its a semi thin piece of metal that squeaks when you lightly press. but when you press harder you bend the tab out of the way temporarily and it stops.
Old Feb 22, 2010 | 01:25 PM
ok i will order up some hawk pads where is the best place to order them from
Old Feb 22, 2010 | 01:37 PM
i has no idea. i was trying to find the old site i found them on but i cant find it anymore
you have a 2.2? if so then these are for you. http://www.modernperformance.com/haw...lt-p-1572.html
Old Feb 22, 2010 | 01:38 PM
i have a 2.4
Old Feb 24, 2010 | 11:04 AM
BULLETSSMOKE's Avatar
scratch that. i got rear OEM rotors and pads off eBay for $70. Fronts are slightly more. Easy install.
OP, replace your rotors and pads, it will eliminate your problem and you wont have to worry about it in the future. Plus your braking will be like new again, really good.
Plus, I see that you have an 06, I just had to replace all my rotors and pads because they were making AWFUL noises, and this was my first time on my 2006. So its probably your time to do that too.
Old Feb 24, 2010 | 02:29 PM
rnjmur's Avatar
Last time I looked you can get Hawk pads and others as well off of tirerack dot com
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
n20saturn
Sep 30, 2015 12:26 AM
