fuel pressure
Old Apr 23, 2010 | 12:55 PM
thecobaltguy's Avatar
fuel pressure
can anyone tell me what the factory fuel pressure is for a '06 SS...i have a modded cobalt and i get catalyst inefficiency and a friend of mine said my fuel is too rich and sitting on top of the cylinder...can anyone help me..
Old Apr 23, 2010 | 03:18 PM
sundevil07's Avatar
do you have a catalytic converter? if not then you will obviously throw this code. you will with a high flow cat as well
Old Apr 24, 2010 | 01:43 AM
i have a high flow cat...GM told me that there is too much fuel getting dumped into the engine and its burning up my cat...to me that sounds like some bullshit but u never know
Old Apr 24, 2010 | 01:48 AM
outtamymind's Avatar
thats what it would be if you had the stock cat as running rich clogs your cat and the efficiency code gets thrown to let you know that your cat if pooched. since you have a high flow cat, the computer thinks that its running rich because less stuff is being filter from the lack of the stock cat.
Old Apr 26, 2010 | 07:27 PM
stonny9's Avatar
first ur running all those mods and no wideband? Second u either u still have ur cat or it blew itself out like what happened to me. Either way ur cat isnt working to gm standards. the code wont hurt anything or cause any performance lose.
Old Apr 27, 2010 | 02:06 PM
liamrh's Avatar
The mix is off on your post cat 02 sensor readings because of the high flow cat. You can get around it a number of ways.
P0141 maybe?
Old Apr 27, 2010 | 02:08 PM
recklessactn's Avatar
welcome to the modded cobalt world?
read all the posts and weep, common knowledge. / thread
Old Apr 28, 2010 | 12:08 AM
insylem's Avatar
IF your getting too much fuel
why is code P0172 NOT throwing??? (System too Rich)
My car was WAAAAAAY rich when I baught it (Modded on a stock tune)
and I only ever got P0172.
Old Apr 28, 2010 | 07:16 PM
your a/f's are fine, since your running a high flow cat that doesn't catch all the emissions and thins them down the second O2 sensor is seeing that something is out of wack, which is why its setting off an efficiency code. if you were to put in the fix for this (spark plug fouler, to take the O2 sensor out of the direct stream) the code will go away
Old Jun 7, 2010 | 12:30 PM
P0420 is the code that keeps coming up....along with another one for multiple misifire. i had a guy look at it and there was un burnt fuel sitting on top of the cylinder and had lost pressure in 2 cylinders cuz of it from what he said
Old Jun 7, 2010 | 05:25 PM
brett5's Avatar
p0420 is bank 1 sensor which is the first o2 sensor...so its not cause of the cat
Old Jun 7, 2010 | 05:27 PM
coopercharge's Avatar
Get the 0420 code tuned out by someone with hp tuners or have zzp 1.0 pcm mod done.
brett5's Avatar
cant tell ya whats wrong but you should def get a wideband
Old Jun 7, 2010 | 06:59 PM
leaking injectors possibly.
Old Jun 9, 2010 | 11:05 AM
i dont know but it really pisses me off....lol....im gonna get the interceptor gauge on payday here in a few days....so P0420 is the first 02 sensor...everybody has been telling me that and gm told me some i was burning my cat up with too much fuel in the engine...i will see about tuning it out if its nothing major wrong with it
Old Jun 9, 2010 | 11:35 AM
The code is for the o2 sensor after the cat. Thats all it does is makes sure that the cat is working properly.
Just get a catless dp they work great.
The 420 code is also for cat inefficiency which is the post cat o2 sensor
Old Sep 9, 2010 | 02:34 PM
i know this thread is a few months old but i have the p0141 code and i got it right after i put the Bosch o2 sensor in
i had the stock o2 sensor hooked up to this o2 sensor extender so it wouldnt get hit by excessive fuel(flow) as im running a high flow cat
and never got the p0141 code and i had this setup for a good yr
but i did get the p0137 code and i was told the o2 sensor was about to be dead pretty much thats why i swapped it and i just have this p0141 code haha
i clear it multiple times and it comes back, i even took the o2 sensor extender off the other day and cleared the code and it came back today
i read that its the Bosch sensor, but just wondered if u guys wanted to add some insight
Thanks
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
